Another approach to assembly solver (A2plus)
Re: Another approach to assembly solver (assembly2relaunch)
Is it relevant to this topic to post the following open issue:
issue #3445: Import Part not working in Assembly2
Hello Kunda1,
I like to help you, but i am not the maintainer of assembly2. I am doing a new workbench based on the ideas of it.
The issue #3445 is probably related to the problems discussed in this thread:
https://forum.freecadweb.org/viewtopic. ... 8&start=20
look for my post and the following post of user easyw-fc in this thread.
Perhaps this tip can help.
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Language
Hello kbwbe,
Don't forget to put a variable for language, so for transduction.
In France, there is a team for translating FreeCAD.
I continue to test A2plus.
I use FreeCAD with pupil 14 and 15 year's old.
Best regard.
Best regard.
New version attached.
Only added one new Constraint: PlanesParallelConstraint. Roughly tested. Seems to work.
Undo function has to wait a little bit.
PlanesParallelConstraint in action, see here.
FOR TESTING DO ALWAYS A FRESH ASSEMBLY. DATASTRUCTURE IS CHANGING MUCH. ASSEMBLIES DONE WITH VERSIONS BEFORE WILL SHOW ERRORS AND WILL NOT OPEN CORRECTLY.
kbwbe
kbwbe
- a2plus-2018-06-20-01.zip
- (571.92 KiB) Downloaded 72 times
KBWBE
Re: Language
Do not have any idea, how to do. I am a not very experienced develper regarding GUI' topics. Someone would have to help.
Would like to implement that.
PS. Your last question related to grouping constraints beneath both involved parts: I did not find the bug until now.
Workaround: if button "updateImportedParts" is been hit, then the treeview will be complete.
kbwbe
KBWBE
Thank you...
KBWBE
Maybe just as @realthunder did, maybe someone could make appImages for each new version update of this a2plus project?
Another idea, one more ...
Have video to explain how to use assembly constraint by a right clic on the mouse.
But it is not a priority.
thank you all for interest in this project. I am just working on code cleanup. Hope to present next version late this weekend.
KBWBE
