I'm sorry, that I ask you for this from time to time. I assume it's only one-to-two clicks for you and two or three commands for me, rather than me needing much time to refactor my local repository. Please complain if that bothers you too much!kbwbe wrote: ↑Fri Jan 18, 2019 2:54 pmHi Manuel,manuelkrause wrote: ↑Fri Jan 18, 2019 2:08 pm Can you please again reset your "improve-colors" branch again to current "devel", that I can clone and restart patching from scratch at current state? Before going the preference step we need to reassure that at least some of my code is working.
all branches are identical at moment.
Another approach to assembly solver (A2plus)
- manuelkrause
Re: Another approach to assembly solver (A2plus)
Hi Manuel,
no problem. Just i am working on devel branch and the new preferences option "usePerFaceTransparency" is already inside it.
You can now use the function
if a2plib.getPerFaceTransparency() == True:
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
- manuelkrause
Hi, you brave A2plus people!kbwbe wrote: ping
O.k. - I've now set up a new [improve-colors] coding trial. It's already in my github, I'd post a PR for that very branch soon, if you'd kindly allow.
I limited coding to:
* re-implementing my and @wandererfan's work
* adjusting it to current code base
* removing/changing minor things
* omitting heavy debug messages
So there will be no big surprise.
+ What seems to be working, is per face colors for assemblies and sub-assemblies
EDIT:
+ Transparency seems to work, too, the only thing about them again is:
/EDIT
- This leads to unselectable faces and artefacts. Latest FC 0.18 fixes didn't cause a difference
- Toggle transparency for assemblies containing sub-assemblies would only show at mouse over the faces.
I haven't tested all of the A2plus facility so far, so there may occur weird things, but I have tried my best to avoid this.
For the Coders among you, please help to improve!
BR,
Manuel
- manuelkrause
No, of course no reset for now, please!kbwbe wrote: ↑Sat Jan 19, 2019 4:55 pmHi Manuel,
to add your additional code in a appropiate section. Shall i reset the branch "improve-colors" to this state again ?Code: Select all
if a2plib.getPerFaceTransparency() == True: ....
I'm quite sure your code fits mine with only some very small edits.
Or vice versa.
Please simply read through the little changes I've made to a2plib within my commit, regarding a2plib.getPerFaceTransparency(). And look at the other functions making use of it.
EDIT: So some kind of "Gedankenübertragung" - how to translate it to English? - My code uses the same function name.
OK, i will look through your new code !
KBWBE
- manuelkrause
Although they're small and easily to rebuild, here are the reference test files for recent [improve-color] testing:
3 Cubes with different Transparency,
one of them with Transparency = 0, but one face differently colored.
sub-assy loads all 3 sub-model part files,
top-assy the sub-assy.
- sub-model.03.FCStd
- (3.35 KiB) Downloaded 35 times
- sub-model.02.FCStd
- (3.35 KiB) Downloaded 43 times
- sub-model.01.FCStd
- (3.36 KiB) Downloaded 38 times
- sub-assy.02.FCStd
- (6.93 KiB) Downloaded 39 times
- top-assy.02.FCStd
- (5.27 KiB) Downloaded 31 times
I rebased your PR to devel branch and merged it there. Devel branch has to be reviewed now, as there are some small unwanted impacts.
KBWBE
- manuelkrause
Maybe. I will check in detail tomorrow.manuelkrause wrote: ↑Sat Jan 19, 2019 8:48 pm what are the "some small unwanted impacts"? If they are not the ones I've already described?
KBWBE
- manuelkrause
Hi Klaus,kbwbe wrote: ↑Sat Jan 19, 2019 9:22 pmMaybe. I will check in detail tomorrow.manuelkrause wrote: ↑Sat Jan 19, 2019 8:48 pm what are the "some small unwanted impacts"? If they are not the ones I've already described?
now, after having a closer look at your devel-branch changes I see what you mean.
I identified at least a collision of my variable usage and your implemented new usePerFaceTransparency preference read-out.
ATM, I prepare a little PR that would heal this collision (I hope correctly).
BR
EDIT: O.k., PR #156 is placed. Please check it before accepting. I hope, all is right.
