Hi Klaus,
is this bug needed anymore today... ?
Missing parentheses in call to 'print'. Did you mean print(cellAdress)? (a2p_bom.py, line 128)
File "<string>", line 66, in Initialize
I'd take it into account soon. Let me finish to conduct some cross testing first.kbwbe wrote: ↑Wed Nov 07, 2018 5:30 pm @manuelkrause,
There is now the feature freeze and bugfix period running for fc-0.18. Perhaps this bug is important.
Best way:
Post a helprequest with title something like: "Testing FC018-pre, undefined symbol in library during start of external WB", with errormessage, your systeminformation, way to reproduce. Even if there is something wrong during experimenting with A2plus, "undefined symbol" should not happen.
Undefined OCC symbol is probably a build/install problem rather than anything you're doing in Python. The Install/Compile forum is the best place to get help for this one.manuelkrause wrote: ↑Wed Nov 07, 2018 4:00 pmThis can be due to my further playing with A2plus colors, or due to missing/ not updated libraries for the v0.18 FC.Code: Select all
During initialization the error /usr/lib64/FreeCAD/lib/Part.so: undefined symbol: _ZN24BRepMesh_IncrementalMeshC1ERK12TopoDS_Shapedbdbb occurred in /home/manuel/.FreeCAD/Mod/A2plus/InitGui.py Please look into the log file for further information
sgrogan wrote: ping
Regarding this tiny one in a2p_bom.py I 've overcome with:manuelkrause wrote: ↑Wed Nov 07, 2018 6:08 pm @kbwbe,
Hi Klaus,
is this bug needed anymore today... ?Code: Select all
Missing parentheses in call to 'print'. Did you mean print(cellAdress)? (a2p_bom.py, line 128) Traceback (most recent call last): File "<string>", line 66, in Initialize
for i in range(0,12): #12 Rows enought for a partlist
for k in range(0,BOM_MAX_LENGTH):
cellAdress = alphabet_list[i]+str(k+1)
print (cellAdress, ss.set(cellAdress, '')) # <-- wrong print fixed
def Activated(self):
doc = FreeCAD.activeDocument()
Same issue occurs with A2p MASTER.kbwbe wrote: ↑Wed Nov 07, 2018 5:10 pmHi Manuel,manuelkrause wrote: ↑Wed Nov 07, 2018 4:00 pm Hi Klaus, @kbwbe,
today I've finally tried to use an openSUSE tumbleweed 0.18-pre FreeCAD version and get this in bash console (as startup in normal KDE GUI failed):There is no log info found anywhere.Code: Select all
Ideas and hints highly appreciated, TIA
it seems to be related to A2plus. Please test with master branch of it (identical to devel ATM), whether the problem still exists or not. If the problem vanishes, it perhaps has to do with color setting experiments.
P.S.: It can be a library problem too... P.S.-II: (as undefined symbol should never happen!)
It works perfect now.This has been fixed with new release V0.1.5.2
Sorry, fixed with V0.1.5.3manuelkrause wrote: ↑Wed Nov 07, 2018 6:08 pmCode: Select all
Hi Herbert,
Looks that way, I can't say much about OpenSUSE. I tested with the AppImage and everything was OK.wandererfan wrote: ↑Wed Nov 07, 2018 6:19 pm Undefined OCC symbol is probably a build/install problem rather than anything you're doing in Python. The Install/Compile forum is the best place to get help for this one.
