Another approach to assembly solver (A2plus)
- manuelkrause
Re: Another approach to assembly solver (A2plus)
@kbwbe:
Can you please, with your next commits, fix the wrong "print" without brackets?
And this other one in devel-branch:
-> inconsistent use of tabs and spaces in indentation (a2p_rigid.py, line 172)
@wandererfan:
Thank you for taking care of the visibility of PartContainers!
I've tested it across a chain of subassemblies, and when properly updating imported parts in the intermediate subassemblies everything remains consistent (visible/invisible as selected in the very first .fcstd part).
Very good work indeed, thank you!
Best regards, Manuel
@wandererfan:
Did you find false prints in "devel" branch ? If yes, where ?manuelkrause wrote: ↑Wed Aug 15, 2018 11:29 am Can you please, with your next commits, fix the wrong "print" without brackets?
If you found them in branch "turro-dof-3", then @Turro75 should fix this within his PR's.
Otherwise i have to redo this after each merge.
I fixed it in devel branch...manuelkrause wrote: ↑Wed Aug 15, 2018 11:29 am And this other one in devel-branch:
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
- manuelkrause
It's line 287 in a2p_importpart.py:kbwbe wrote: ↑Wed Aug 15, 2018 12:15 pmDid you find false prints in "devel" branch ? If yes, where ?manuelkrause wrote: ↑Wed Aug 15, 2018 11:29 am Can you please, with your next commits, fix the wrong "print" without brackets?
print "imported Object is empty/none"
Fixed in "devel" branch.manuelkrause wrote: ↑Wed Aug 15, 2018 12:21 pm It's line 287 in a2p_importpart.py:
KBWBE
- manuelkrause
Thank you!
Now I'm only waiting for your fix for "recalculating the refPointsBoundBoxSize when calculating the spincenter"...
(Edited wrong copy/paste)
- manuelkrause
@kbwbe:
I hope you allow me some nitpicking before going for release...
IMO two points should be fixed therefore:
* Cannot find icon: preferences-a2plus
Group icon for preferences-a2plus is not of size 96x96
* When using "Edit imported part" and the imported part is a subassemby it fails and gives the following in Report view:
Running the Python command 'a2p_editImportedPart' failed:
File "/home/manuel/.FreeCAD/Mod/A2plus/a2p_importpart.py", line 458, in Activated
obj = selection[0]
list index out of range
EDIT:
Sorry, I was too fast...
It does NOT fail!!!
It only spits out the mentioned error message.
/EDIT
Regards
obj = selection[0]
EDIT:
It does NOT fail!!!
/EDIT
Regards
- manuelkrause
@kbwbe:
Just forget the last point... It only happens, when having another part in the foreground and using "Edit" on a non activated assembly part in Tree view -- what is quite logical.
Sorry for the noise.
@wandererfan,manuelkrause wrote: ↑Wed Aug 15, 2018 2:29 pm @kbwbe:
need your help. I do not get the .ui-file working regarding the icon for preferences page. Is there a trick ??
This happens, if you try to edit a part but you don't have selected one.manuelkrause wrote: ↑Wed Aug 15, 2018 2:29 pm * When using "Edit imported part" and the imported part is a subassemby it fails and gives the following in Report view:
obj = selection[0]
It is fixed on "devel" branch. Now you get a console warning.
KBWBE
@Turro75,
i need your help.
How can i do a function like that:
booleanResult = rigid.isFullConstrainedTo(anotherRigid) ?
i need your help.
KBWBE
The function below does nearly what You need, it checks if tempfixed linked obj fully constraint the rigid.
def linkedTempFixedDOF(self):
self.pointConstraints = []
_dofPos = a2p_libDOF.initPosDOF
_dofRot = a2p_libDOF.initRotDOF
self.reorderDependencies()
if not self.tempfixed:
if len(self.dependencies) > 0:
for x in self.dependencies:
if x.dependedRigid.tempfixed:
_dofPos, _dofRot = x.calcDOF(_dofPos,_dofRot, self.pointConstraints)
return len(_dofPos) + len(_dofRot)
Just be sure that point constraint deps are evaluated as last, reorderdependency does this.
This is taken from a2p_rigid in turro dof 3
