Another approach to assembly solver (A2plus)
Re: Another approach to assembly solver (A2plus)
Post by Kunda1 »
dan-miel wrote: Mon Mar 14, 2022 10:20 pm Done. I renamed ConstraintViewer to ConstraintDiagnostics but it is the same workbench.
URL for the split off topic ?
dan-miel
Post by dan-miel »
Kunda1 wrote: Tue Mar 15, 2022 1:28 pm URL for the split off topic ?
[url]https://forum.freecadweb.org/viewtopic. ... 85094b[url]
Also: I have modified the files so it can be a PR to A2+.
dan-miel
Post by dan-miel »
Kunda:
These functions are being added to the A2plus assembly program.
The information is here https://forum.freecadweb.org/viewtopic.php?f=20&t=67258.
We don't want to sidetrack this thread, so please post any comments about these two features on the new thread.
Dan Miel
svbol
Post by svbol »
Workbench have version 0.4.59d now.
And support 7 languages.
All language files placed on github:
https://github.com/kbwbe/A2plus/tree/ma ... anslations
If you can help - you can:
1. Download your language file (or download A2plus.ts for new language),
2. Open in QT 5 Linguist,
3. Translate file,
4. Upload translated file to github or on this topic.
kemes
Post by kemes »
OS: Ubuntu 20.04.5 LTS (XFCE/xfce)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Installed mods:
  * A2plus 0.4.59
Does anybody else face such an error when trying to update through the Addon manager?
onekk
Post by onekk »
kemes wrote: Wed Oct 05, 2022 6:34 am ...
It seems a git error about something changed in the destination repo (your Mod dir) when AddOn Manager try to do a "git pull --ff-only" it detect that things have changed.
If you don't have do modifications, try to simply uninstall the AddOn, delete eventually leftovers, and reinstall.
If you have done modification to the sources decide what to do.
Regards
Carlo D.
- Various other stuffs.
kemes
Post by kemes »
Thanks for the tips! I have not modified anything.
roerich_64
Post by roerich_64 »
Hi Klaus and all,
I have problems to assemble easy things:
Now, i am here:
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.21.0.31488 (Git) AppImage
Hash: 3e58513c24e533326906be5c87c82aafe582c936
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * sheetmetal.backup1663267330.3384569
  * Lithophane
  * BIM 2021.12.0
  * sheetmetal 0.2.60
  * Glass.backup1663237728.6533988 (Disabled)
  * DynamicData 2.46.0
  * A2plus 0.4.60g
  * Glass (Disabled)
  * TabBar
  * kicadStepUpMod 10.16.8
  * fasteners
  * ExplodedAssembly
  * FeedsAndSpeeds 0.5.0
  * freecad.gears 1.0.0
  * 3D_Printing_Tools
Now the file with the parts:
Rohr_Monitorhalterung_asm.FCStd
(126.63 KiB) Downloaded 116 times
Ok, what is the problem?
I can not assemble it as it shouldt...
Sorry, it is an whery easy assembling... but for now A2plus is not to use...
Klaus, to you and your family, when you have not the time to fix anything, it is not a problem.
Die Liebe wird siegen, denn sie ist unzerstörbar :) ;)
roerich_64
i have found the issue.
The issue was between my two ears... :lol:
After i builded subassemblys it works fine.
Sorry for the dust I kicked up...
Walter
MRx
Post by MRx »
when checking for constraints sometimes things blow up and then popups seem to come up endlessly...
Can you add something like this:
diff --git a/a2p_searchConstraintConflicts.py b/a2p_searchConstraintConflicts.py
index 544b389..628f0df 100644
--- a/a2p_searchConstraintConflicts.py
+++ b/a2p_searchConstraintConflicts.py
@@ -48,6 +48,8 @@ class a2p_SearchConstraintConflictsCommand:
     def Activated(self):
         doc = FreeCAD.activeDocument()
+        yesflag = False
+        counter = 0
         workList = []
         constraints = [ obj for obj in doc.Objects if 'ConstraintInfo' in obj.Content]
@@ -92,16 +94,25 @@ Do you want to delete this constraint-pair?
     ob1.Label,
     ob2.Label
-                flags = QtGui.QMessageBox.StandardButton.Yes | QtGui.QMessageBox.StandardButton.No
-                response = QtGui.QMessageBox.information(
-                    QtGui.QApplication.activeWindow(),
-                    translate("A2plus_searchConstraintConflicts",'Searching for conflicting constraints'),
-                    message,
-                    flags
-                if response == QtGui.QMessageBox.Yes:
+                response = None
+                if yesflag == False:
+                    flags = QtGui.QMessageBox.StandardButton.YesToAll | QtGui.QMessageBox.StandardButton.Yes | QtGui.QMessageBox.StandardButton.No
+                    response = QtGui.QMessageBox.information(
+                        QtGui.QApplication.activeWindow(),
+                        translate("A2plus_searchConstraintConflicts",'Searching for conflicting constraints'),
+                        message,
+                        flags
+                if response == QtGui.QMessageBox.YesToAll:
+                    yesflag = True
+                if response == QtGui.QMessageBox.Yes or yesflag == True:
                     a2plib.removeConstraint(c)
+                    counter=counter+1
         a2plib.SHOW_WARNING_FLOATING_PARTS = True
+        if counter > 0:
+            print("removed %d constraints" % counter)
     def IsActive(self):
         if FreeCAD.activeDocument() is None: return False
