roerich_64 wrote: ↑Fri Mar 15, 2019 6:03 am
More than one array comes not through:
Hi Walter,
i have done some investigations why one of your arrays is missing. The reason i have found is perhaps a little bit difficult to understand. I try to explain.
- "Array001" depends on "Array", as it is using some data of it. (IntervallY, NumberY)
- As "Array" is been used by "Array001", A2plus is not able to detect, that "Array" is a top level object of which the shape has to be imported.
Because of this "Array" is not imported and therefore missing within the assembly.
I reworked your Dach_Master.FCStd and introduced a spreadsheet. All calculation is done there. Both Arrays now take data from the new spreadsheet and they do not depend on each other anymore. Now it works.
- Dach.png (247.66 KiB) Viewed 1627 times
I attach the files.
BR, Klaus
