Another approach to assembly solver (A2plus)
manuelkrause
Re: Another approach to assembly solver (assembly2relaunch)
Post by manuelkrause »
kbwbe wrote: Tue Jul 10, 2018 5:14 pm
manuelkrause wrote: Tue Jul 10, 2018 5:08 pm @kbwbe:
What do you think: Can I help you a little by adding some more documentation to the README.md at "Usage of A2plus workbench:"? First only a feature list with some copy&paste of the tooltips' information?
Appreciated. Please PM drafts.
I don't want to irritate your workflow. I may stumble over typos in the code files' tooltips, that I could fix as well, when at it. So I'd prefer to send you a diff style patch in PM. If you don't agree, just make a different proposal that's most convenient for you.
jpg87
Re: Another approach to assembly solver (A2plus)
Post by jpg87 »
I started (positive) tests with A2p.
I have a question for the moment: how do we test the remaining movements after one or more constraints?
... and a check: is the first integrated part always the reference part (locked in a transparent way)?
Thank you in advance and good job.
My website : http://help-freecad-jpg87.fr updated 2023/11/06
Turro75
Post by Turro75 »
jpg87 wrote: Tue Jul 10, 2018 7:08 pm Hello,
Good point. For what I've seen in the source it is. I didn't understand how priorities are handled, it looks like the order is the creation of the constraints as a fifo.
In complex assemblies could be mandatory start solving from constraints which involve fixed parts, then go to the others by threating the first object as fixed part.
I remember solidworks that allowed to change the order of the solver and it was also possible disabling a specific constraint.
manuelkrause
Turro75 wrote: Tue Jul 10, 2018 7:45 pm
Yes, this had been the great advantage of the last solidworks I had used, too. Anyways, we'd alltogether make the A2plus at least as powerful. Over time. :-)
kbwbe
Post by kbwbe »
@jpg87
thank you for testing...
Answers to your questions:
- test remaining movements after constraining: ATM nothing special implemented, just move/rotate part manual away and solve again. You will see what is missing.
- reference part:
Same as in Assembly 2. The first imported part is automatically fixed (Fixed Position = True in object tree)
You always can edit this property to False. But in this case you should fix another one instantly. Otherwise your whole assembly will move free
in coordinate system. As the solver will move each part which is constrained and not fixed.
@Turro75
FYI: There is no priority of constraints. Order of creation does not matter. You have the fixed parts and all others. The solver calculates the move data of all movable parts and then, in next step, it moves all parts quasi simultan. But it is recommended to set constraints first to the fixed part, second to the neighbors etc.
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
jbe
Post by jbe »
Can you add a button to symmetry the last constraint, especially for plane-to-plane constraints (to return a part).
There is this button in Assembly 2, and it was very useful.
Thank you.
Turro75
Post by Turro75 »
kbwbe wrote: Tue Jul 10, 2018 8:21 pm
@Turro75
Hi Kbwbe,
Your solver is effective but I think it would improve by handling priorities and by keeping low the number of rigids involved during calcmovedata.
let's say we have an assembly with a structure like this: Part1 is fixed and arrows identify a constraint and obj1 to obj2.
At the moment the solver skips all rigids marked as fixed. which is good. My suggestion is to create 2 new parameters:
a list of "fathers" rigids and
a temporary fixed parameter which is set to rigid.fixed at the creation of the rigid. then it become true as all "Fathers" are marked as tempfixed EDIT and successfully solved END EDIT.
every rigid should be involved in calculation only if all fathers are marked as tempfixed.
coming back to the picture above the solver should do this sequence:
fix part1 (which is already marked as fixed)
solve part2 and part4 and mark them as tempfixed
solve part3 part5 part6 part8 and mark them as tempfixed
solve part7
does this make sense for You?
kbwbe
Post by kbwbe »
Hi @Turro75,
very good. I am just sitting here and are thinking about exact same things. Solver will needs more logic to control such things.
This will save a lot of computation time.
KBWBE
Turro75
Post by Turro75 »
Well I was sure You agreed
moreover if there are moveable rigids but none of them has all fathers tempfixed so the assembly is not valid and You can immediately stop calculation.
Of course the constraint can be wrong, but at least You can catch in advance if the sequnce is correct or corrupted.
Another advantage, the order of insertions of parts and constraints is not important the only thing is respecting these 3 rules:
1) in an assembly at least one part must be marked as fixed
2) when creating a constraint always select as first the reference object and then the object that must be moved.
3) manually pay attention to recursive constraint creation
I think it's difficult doing it better than this.
I worked for Years with commercial grade CAD and ignoring the 3 rules above caused an unresolved assembly in the 100% of the cases.
manuelkrause
Am just playing with some subassembly operations. What is easier from the solver's sight ATM: circularEdgeConstraint with value offset edited, or the two corresponding ones, first axialConstraint and second planeCoincidentConstraint with edited offset? Hope, I haven't ask this before on here and you don't consider it too dumb.
EDIT
And again something forgotten to ask: Does the "Update parts" work recursively over sub-assemblies? Any known limits?
EDIT END
TIA,
Manuel
