Another approach to assembly solver (A2plus)
roerich_64
Re: Another approach to assembly solver (A2plus)
Post by roerich_64 »
Hi Klaus,
thanks for the fast update :)
After i have delete the complete A2Plus folders and i maked a new installation with the addonmanager, it works.
Tested with:
OS: Windows 7
Version: 0.18.16065 (Git)
Hash: 8f58abfd4961c645b3b4d7ffeea65fd551b7159b
Python version: 2.7.14
OCC version: 7.2.0
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 3.6.6
Qt version: 5.6.2
BR
Walter
Die Liebe wird siegen, denn sie ist unzerstörbar :) ;)
manuelkrause
Post by manuelkrause »
kbwbe wrote: Mon Apr 01, 2019 9:43 am ...The newly released FC0.18 stable does not provide a build number and breaks the FC version check of A2plus. Starting A2plus, an error "list index out of range" is thrown.
This is fixed with version V0.4.12. Please update your A2plus WB.
Hi Klaus,
many thanks for your continued valuable work on A2plus!
I hope that the version check doesn't inhibit the work of A2plus: Reason to write this, is that openSUSE Tumbleweed (unstable science repo) never shipped with either a subversion nor a commit number (third value == UNKNOWN).
Now they're going with FC's development progress with 0.19-pre, what I haven't tested so far.
Best regards
roerich_64
to open an assembly it needs a huge time now (~2min) after the update.
Will open an assembly file with 3 parts.
One of them an alu profile, two of them a FreeCAD file with an included STL.
Have build a ZIP. Who should i send it?
BR
Walter
kbwbe
Post by kbwbe »
roerich_64 wrote: Mon Apr 01, 2019 7:27 pm
Hi Walter,
nothing related to performance of A2plus should have been changed during it's last updates. You can send your test assembly to me. I will check it with different FC versions.
BR, Klaus
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
roerich_64
Hi Klaus,
thanks for the fast response.
Have done more testing.
i think files with STL's have the most problem to open. Here an example screenshot. I will open a file with a ballscrew and his two ball-bearing after 10min...:
Volle Rechenleistung von vier Kernen und große Nutzung des Arbeitsspeichers.jpg
Volle Rechenleistung von vier Kernen und große Nutzung des Arbeitsspeichers.jpg (754.61 KiB) Viewed 1462 times
BR
Walter
kbwbe
Post by kbwbe »
roerich_64 wrote: Mon Apr 01, 2019 9:33 pm i think files with STL's have the most problem to open.
Hi Walter,
this explains the performance problems. STL's create huge numbers of geometry elements, killing the performance completely. Much better is importing the parts from step files e.g.
BR, Klaus
KBWBE
roerich_64
Another interesting effect:
The framerates of the lowest file (1) are very fast. In this is the STL of the DB_9 plug imported.
The framerates of (2) and (3) are very low.
Here we see the 'display mode' of all files in 'shaded' mode:
(1) is ok
(2) the db_9 plug are hidden
(3) the db_9 plug are in wireframe and colored green as it would be selected...
roerich_64
kbwbe wrote: Mon Apr 01, 2019 9:59 pm
Hi Walter,
BR, Klaus
Before the update there were no problems with the STL ;)
kbwbe
Post by kbwbe »
roerich_64 wrote: Mon Apr 01, 2019 10:14 pm Before the update there were no problems with the STL ;)
Both screenshots above, view (1):
View (1) has nothing to do with A2plus, but fps goes from 40,2 in first screenshot to 16,3 in second one. fps seems to depend heavily on view modes.
Both screenshots above, view (2):
Second screenshot should have a higher frame rate, as the connector is invisible. But it changes from 0,5 fps to 0,1 fps and is much slower. (but you also changed the view mode to shaded)
It seems to me that perhaps the newer FC causes some performance problems.
P.S.: I just tested some bigger assemblies on my side. I cannot see so low frame rates as shown in your screenshots. Strange. I tested with newest and fresh compiled FC0.19
P.S.-II: The frame rates are showing complete nonsense, as heavily depending on pauses between moves. The values are not constant.
KBWBE
roerich_64
I dont think that is an global FC issue.
https://www.youtube.com/watch?v=9Irh9UF ... e=youtu.be
