Thank you, this was fast!Turro75 wrote: ↑Tue Sep 11, 2018 11:59 pmPR sentTurro75 wrote: ↑Tue Sep 11, 2018 9:10 pmlet me trykbwbe wrote: ↑Tue Sep 11, 2018 8:42 pmHi Turro,Turro75 wrote: ping
one question: Is it possible for you to do a PR with the two solver solution to devel branch next days ? Or do we have to merge manually ?
Important: the PR should only include your core modifications so that there is no big impact to current devel state. Our standard solver should keep on working as before.
Another approach to assembly solver (A2plus)
Re: Another approach to assembly solver (A2plus)
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Well...kbwbe wrote: ↑Tue Sep 11, 2018 3:14 pm Hi Koemi,
if you put e.g. a fastener from fasteners WB to A2plus file, at first moment it is no correct A2p import part. You can select the new fastener, hit the "convert" button and the fastener turns to be a A2p part. From this point on, you can correctly set constraints to it and do all usual A2p operations.
I discovered that parts made with FC_V0.16 also cannot be used with A2Plus without 'convert'...
Message: "Import error: no visible part to import found. Aborting operation". Report view notification: "imported Object is empty/none"
But there IS a part visible...
So, I made a copy of the part (just in case); opened it; clicked the 'convert' button; saved it. And after this procedure the part is accepted with A2Plus.
Then I tried if the converted part still functions in FC_V0.16: it did
Then I tried if the converted part still functions in A2 (no plus): it did
I am used to the fact that updated software eats any older version file and files created with updated software cannot be opened with an older version. Now I have the opposite
I now say carefully that parts will not be damaged after conversion with A2Plus
Hi Koemi,
in this case, there seems to be a problem with the file importer. It is not intended. We will check...
Please post a not importable file.
KBWBE
Ok. Here's that file. I also added the file which was converted.
I also noticed that after conversion the part and corresponding sketch are on the same level in the tree... It looks like if the sketch does not belong anymore to the part...
- metal strip converted.FCStd
- (7.31 KiB) Downloaded 30 times
- metal strip.FCStd
- (7.25 KiB) Downloaded 30 times
A2p is not intended to be used an a single part document. It is only for use with A2p assembly files. If using on wrong files, they could be damaged.
KBWBE
eehrr... This is the message when i swipe over the convert button....
So I understand that at this moment it is not possible (for me) to add earlier created parts ( < FC_V0.17) inside A2P?
Please keep patiently, i am working on that problem...
KBWBE
I am so very patient...
And now I found another bug, sorry...
The following happens:
I call the file "Alu_profiel 30x15x3_150" and save it.
When I add this file in A2P the file is known as: "Alu_profiel 30x15x3_001".
What happended to my "150"?
This effect happens if I create a part using FC_V0.16 and converted it with A2P AND If I create a body (...) with FC_V0.17
Hi wandererfan,wandererfan wrote: ping
@Koemi, see posts before, could not import the file being attached. It is done with pure FC16.
In importer, we need the section for:
obj.isDerivedFrom("PartDesign::Feature") for FC16 parts. Obs are filtered out at moment.
I tried to modify the importer:
def filterImpParts(obj):
impPartsOut = list()
if obj.isDerivedFrom("Sketcher::SketchObject"):
pass
elif obj.isDerivedFrom("PartDesign::Body"):
# we want bodies that are top level in the document or top level in a container(App::Part)
# we don't want bodies that are inside other bodies.
if ((not(obj.InList)) or \
((len(obj.InList) == 1) and (obj.InList[0].hasExtension("App::GroupExtension")))): #top of group
plmGlobal = obj.getGlobalPlacement();
plmLocal = obj.Placement;
if (plmGlobal != plmLocal):
obj.Placement = plmGlobal # should obj be a copy here? not in orig doc - maybe no problem?
impPartsOut.append(obj)
elif obj.hasExtension("App::GroupExtension"): # App::Part container. GroupEx contents are already in list,
pass # don't need to find them
elif obj.isDerivedFrom("PartDesign::Feature"):
plmGlobal = obj.Placement
try:
except:
pass
if (
hasattr(obj,"ViewObject") and
obj.ViewObject.isVisible() and
hasattr(obj,"Shape") and
len(obj.Shape.Faces) > 0
elif obj.isDerivedFrom("Part::Feature"):
try:
except:
pass
if not(obj.InList):
impPartsOut.append(obj) # top level in within Document
elif (len(obj.InList) == 1) and (obj.InList[0].hasExtension("App::GroupExtension")):
impPartsOut.append(obj) # top level within Group
elif a2plib.isA2pPart(obj): # imported part
else:
pass # more odd PF cases?? BaseFeature in body??
else:
pass # garbage objects - Origins, Axis, etc
return impPartsOut
- metal strip.FCStd
- (7.25 KiB) Downloaded 31 times
KBWBE
Find a bugfix v0.1.1 release on github for this error. Please update A2plus...Koemi wrote: ↑Wed Sep 12, 2018 8:05 amWell...kbwbe wrote: ↑Tue Sep 11, 2018 3:14 pm Hi Koemi,
I will be offline for perhaps 2 or 3 days. Next bug, you found, i will work on later.
KBWBE
