EskiBrew wrote: ↑Tue Sep 18, 2018 9:42 am
Hi all, Manuel kindly pointed me here after I asked about the current state of the different assembly workbenches.
Is there a "getting started" post for A2Plus? - I can see there are 104 pages of comments here. I could read through all them but that will take quite some time
You can have a look at the bottom of this page:
https://github.com/kbwbe/A2plus#usage-o ... -workbench
There is a brief explanation about what each button does.
(I just noticed that we have to update it a little bit...)
I thought I'd just jump in - created a new empty document and then in the A2plus workbench, I can click the "add Part from external file" icon but rather than add it to my new document, it seems to open the part. If I click it again, selecting a different part, it just opens that part in another new window too rather than adding it to my existing window. Can't seem to see what I am doing wrong there...It does not seem to do the same thing as Assembly2.
Regarding this I'm really confused... This is not intended.
Do you get some error messages in either Report view or Python console?
We definitely need more info to debug this.
I thought instead I'd open an assembly created with Assembly2 - that opens ok and I deleted all Assembly2 constraints and added some new ones but I can't seem to get the new constraints to work - I tried adding an axialConstraint and also a planeCoincident constraint - they do not seem to do anything. What am I missing?
Most likely you haven't set one (e.g. the first) part as "fixed Position" = true. The current solver depends on it to build up the dependencies to the other parts.
I tried the "convert part to A2plus form", not understanding what that was for but that does not seem to help.
This is from the code description: "changes a regular FreeCAD object into an A2plus importedPart, adds the importedPart to the document and removes the FreeCAD object from the document".
