@tripuls,
found some bugs in fixed them. Find attached latest version a3-0.0.1. In my test, new version could solve the problematic file. Perhaps you have to flip plane-constraint with align/opposed options.
I also deactivated the projectFolder stuff.
Hi to all others,
find here attached a new version of my "assembly2relaunched"
System requirements now:
- for fc0.16
- Win and Linux should work (Win not tested, do not have a machine, but all Linux-specific stuff is removed)
How to work with:
- Just copy extracted folder to your mod-folder
- start fc0.16
- find a3-Symbol within available workbenches
- activate a3
- do work analog to assembly2 (best test it with all your fcstd-files newly created)
- use the symbol with the two champagner-glasses to make your assembly transparent and check it always
Enjoy (I hope...)
Limitations:
- before setting of an constraint, orient the new part nearly correct for placing ( helps solver to find correct solutions)
- if constraints are not solvable, atm you will get a wrong solution without warning and undo-function. (save your file often)
- solver atm only does 3000 steps to find a solution, ignoring the reached accuracy. Hitting solve-button more than once will increase accuracy
- atm only 3 type of constraints
Future:
- adjust solver-steps to required accuracy
- give warning if not model is not solvable
- undo of the last solvingprocess
- more constraints
- move to fc0.17
thanks for downloading and testing..
kbwbe
