Another approach to assembly solver (A2plus)
kbwbe
Re: Another approach to assembly solver (A2plus)
Postby kbwbe » Thu Nov 01, 2018 6:14 pm
there is a new release v0.1.5 available.
It contains the new basic partlist functionality, see my post before.
KBWBE
latest release: v0.4.40a, installable via FreeCAD's addon manager
Tutorials:
Paul Randall: https://youtu.be/mnkecA9S7kc
anisim (deutsch): https://www.youtube.com/watch?v=vDcaFq6IEJM
dcapeletti
Postby dcapeletti » Sat Nov 03, 2018 1:19 pm
Hello, again thank you very much for your work.
I've been testing this new function and found an error.
When I enter an expression in some field of the original part spreadsheet, for example =Pad.Length (first image), the assembly spreadsheet shows an error (second image).
I think this is because when you build the spreadsheet in the assembly, you can't evaluate the expression and therefore show an error.
I think you can try the following solution:
1) Evaluate the recursive expression of the original part spreadsheets when creating the spreadsheet in the assembly. This way, you could get the result in a string and not generate the error. This could be done by identifying the = sign.
Look at this post I created https://forum.freecadweb.org/viewtopic.php?f=3&t=32004
Greetings
second image.png (60.86 KiB) Viewed 556 times
first image.png (70.29 KiB) Viewed 556 times
kbwbe
Postby kbwbe » Sun Nov 04, 2018 11:20 am
Hi @dcapeletti,
My implementation ATM does not intend evaluating spreadsheet /EDIT: formulas within foreign files. It is only designed for transporting some static cell entries (without formula within), as e.g. necessary to do a partlist.
Maybe, as "=Pad.Length" is finally a static entry in another object, it should be possible to modify the "a2p_fcdocumentreader" to follow such entries and make it returning the correct value instead of an error. But more complicated formulas sure will not work.
I will keep it in mind for future versions. Recent version is not able to do this.
KBWBE
Tutorials:
dcapeletti
Postby dcapeletti » Sun Nov 04, 2018 11:37 am
Hi, maybe this topic is dealt with in the string expression request https://freecadweb.org/tracker/view.php?id=3460
Anyway, sooner or later we'll have to find a way to solve it. I will try to read your code when I have time, I will do some tests.
Greetings
kbwbe
Postby kbwbe » Sun Nov 04, 2018 1:43 pm
there is a new version of A2p available, V0.1.5.1
What has been changed ?
- bugfix for partlist. I did not work for assemblies done with older versions of A2p (without "subAssembly" property). Now it works (but without recursive iteration over subassemblies)
- pointOnPlane-constraint has been improved. I now accepts a center of a circle as point selection and it got a offset property. Now we can constraint a cylinder within a slot.
Please see here:
KBWBE
Tutorials:
dcapeletti
Postby dcapeletti » Mon Nov 05, 2018 10:06 am
Hi, when I try to generate a parts list and the file hasn't been saved, it generates an empty list.
Steps.
I create a file and save it.
I import the parts.
I create a parts list spreadsheet. It is generated empty.
I save the document and generate it again, it is filled in.
I think I should save the document or warn the user somehow.
Greetings
kbwbe
Postby kbwbe » Mon Nov 05, 2018 10:27 am
Thanks, i will fix the bug soon.
KBWBE
Tutorials:
kbwbe
Postby kbwbe » Wed Nov 07, 2018 1:29 pm
This has been fixed with new release V0.1.5.2
KBWBE
Tutorials:
manuelkrause
Postby manuelkrause » Wed Nov 07, 2018 4:00 pm
Hi Klaus, @kbwbe,
today I've finally tried to use an openSUSE tumbleweed 0.18-pre FreeCAD version and get this in bash console (as startup in normal KDE GUI failed):
During initialization the error /usr/lib64/FreeCAD/lib/Part.so: undefined symbol: _ZN24BRepMesh_IncrementalMeshC1ERK12TopoDS_Shapedbdbb occurred in /home/manuel/.FreeCAD/Mod/A2plus/InitGui.py
Please look into the log file for further information
There is no log info found anywhere.
This can be due to my further playing with A2plus colors, or due to missing/ not updated libraries for the v0.18 FC.
Ideas and hints highly appreciated, TIA
kbwbe
Postby kbwbe » Wed Nov 07, 2018 5:10 pm
Hi Klaus, @kbwbe,
Hi Manuel,
it seems to be related to A2plus. Please test with master branch of it (identical to devel ATM), whether the problem still exists or not. If the problem vanishes, it perhaps has to do with color setting experiments.
P.S.: It can be a library problem too... P.S.-II: (as undefined symbol should never happen!)
KBWBE
Tutorials:
