Another approach to assembly solver (A2plus)
jbe
Re: Another approach to assembly solver (A2plus)
Postby jbe » Tue Oct 22, 2019 6:50 pm
I don't arrive to assembly this two part.
Someone could help me ?
Mur de la lanterne.FCStd
(14.76 KiB) Downloaded 20 times
Coupole supérieure.FCStd
(28.42 KiB) Downloaded 18 times
I need an axial constraint, and plane coincident.
It's to do that.
Thank you.
Assemblage complet.FCStd
(33.1 KiB) Downloaded 18 times
jbe
Postby jbe » Tue Oct 22, 2019 7:13 pm
Don't worry, I just found the error.
The name of the file was : Coupole supérieur, and when I rename the file as Coupole Superieur, ( no accent on e form superieur), all is correct.
Three hours to find this error ....
Conclusion: No accent in the name of the file for A2plus.
Best regard
jbe
Postby jbe » Fri Oct 25, 2019 4:16 pm
Hello
I would like to know, if is it possible to add an assembly do with A2plus, to a body of Part Design, and then to use this assembly like a part of FreeCAD.
My problem is to do and hole between all the assembly.
Best regard.
assemblage mur et coupole.FCStd
(19.02 KiB) Downloaded 32 times
kbwbe
Postby kbwbe » Fri Oct 25, 2019 4:34 pm
Hi jbe,
In standard mode this will probably cause problems. A2+ tries to generate solids. But often this is not possible and the resulting assembly will be a shell. If this happens, you cannot do holes through it.
But you can activate the option "use solid union..." in preferences. With this option, all parts are "fused" to a solid and you can use the assembly as base feature for a part design body. Part Design will work as long as there are no gaps between the parts. It requires one continous solid. If Part Design fails due to this, you could work with the Part WB to do your holes.
KBWBE
latest release: v0.4.52, installable via FreeCAD's addon manager
Turro75
Postby Turro75 » Fri Oct 25, 2019 5:28 pm
Hi All,
I made a small modification on partslibrary macro, now it runs in my system (details below).
I changed the behavior of double click, now it imports files as a2p objects.
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
PartsLibrary.FCMacro
(17.09 KiB) Downloaded 21 times
GlouGlou
Postby GlouGlou » Fri Nov 01, 2019 4:03 pm
I'm trying to hole 2 parts after their assembly.
I use bodies cloned for do that.
But the second part seems not be an expected behavior: it don't move if I change the first part (the bloc start).
Here my files. Change the BlocDépart 's pocket position to check out that. ;)
OS: Windows 10 (10.0)
Version: 0.19.18644 (Git)
Hash: 481870be2b48ef95b59acf1440b069d42b6fad23
Python version: 3.6.7
Qt version: 5.12.1
Locale: French/France (fr_FR)
PièceFixée.FCStd
(9.45 KiB) Downloaded 21 times
BlocDépart.FCStd
(14.69 KiB) Downloaded 17 times
assemby_drilled.FCStd
(35.5 KiB) Downloaded 19 times
kbwbe
Postby kbwbe » Sat Nov 02, 2019 10:32 am
Hi @GlouGlou,
usually it is no good idea to mix up work with A2plus and other workbenches in one file.
Problem 1 here: After cloning, the clone get's an independent (decoupled) placement of its original. If the original is moved, the clone is not. As the A2plus constraints are only operating at the originals, the clones are not moved accordingly.
Problem 2: I tried to follow your hints and moved the pocket in the block depart. When updating the assembly, the sketches in "body def drill" jumped to false positions. For sure some toponaming issue. See here:
It would be better, if you do such a small assembly completey with the PartDesign WB. If you need it later in a bigger assembly, you can import it complete or only single part of it to a main assembly.
KBWBE
GlouGlou
Postby GlouGlou » Sat Nov 02, 2019 2:47 pm
thanks for that. It's a try to modify an assembly afterward. ;)
https://forum.freecadweb.org/viewtopic.php?f=12&t=40353
Postby Kunda1 » Sun Nov 03, 2019 5:52 pm
A2plus Workbench wiki page doesn't have a Scripting section on the wiki. Can we start to document scripting in A2plus ?
Postby Kunda1 » Tue Nov 19, 2019 12:52 pm
Bump.
Reason: users aren't aware it's possible to animate assemblies. See https://forum.freecadweb.org/viewtopic. ... 11#p348308
