Another approach to assembly solver (A2plus)
kbwbe
Re: Another approach to assembly solver (A2plus)
Postby kbwbe » Sun Apr 26, 2020 1:01 pm
dan-miel wrote:
Sun Apr 26, 2020 11:54 am
I changed more in the "a2p_solversystem" I took and added some more ideas for checking constraints and stuck everything in the a2p_solversystem file. After finding the first constraint it checks every constraint on that part to see which is causing the conflict. I probably missed something but I think the basic concept is there.
Hi Dan,
thanks for all your work. I took up your ideas and implemented a new command to A2plus, in order to find the conflicting constraints.
Updating to new version A2plus V0.4.47, you will find this new button:
This command solves the constraints one after another and is showing the first conflicting constraint which can be deleted instantly, if wanted.
I hope it works.
KBWBE
latest release: v0.4.52, installable via FreeCAD's addon manager
dan-miel
Postby dan-miel » Wed Apr 29, 2020 9:29 pm
kbwbe:
Thanks for adding the commands that you have and for the amount of time you have spent looking at the efforts I've made to make a constraint fixer program. One reason I'm pushing for this is, at least the way I see it, if A2plus gets configurations the conflict problems are many because when moving from one configuration to another you move the constraints also, which can make a mess.
The “a2p_solversystem.solveConstraints” command is great. It retrieves the blasted constraint that causes the problem. ‘PS’ not all of my conflicts are caused by the last one and this command finds them.
Adding the ability to add some mates to a list and run just the list instead of all of them is great also. I hate to sound like a complainer but here goes anyway.
1. I like the ability to turn off the error messages. I noticed the error messages for the parts that don’t move are now popping up one at a time instead of as a list like they did before. Would you put them back into a list and perhaps give us a chance to retrieve the list so I can handle them in a different way? ( Do you like the way I said “we” and “us”?)
2. The matelist for solving constraints: When I’m solving many lists there is a lot of print flowing into the report window and it can be hard to find information that I print. Can we have an option to turn it off.
3. When the error message pops up: Many times I’m zoomed in or out and the errors are outside my screen or small or hidden. The screen is frozen because the popup locks it so I cannot find the parts. Could the form be changed so we could look around?
Lastly I’m attaching my latest poorly written attempt and a picture. The new commands saved time, coding and I did not need to change the solver file to get the conflict. I can leave the form open and work. When the cursor enters a cell in the table the information in cell highlights. Column 2 highlights both legs of the constraint, columns 3 ,4 highlights one leg at a time. Column 1 shows if the constraint is suppressed, 5 and 7 shows if the part is fixed. When a check is done and a conflict is found the program reads which two parts the constraint legs are attached to then finds the other constraints that are attached to the same parts and send the constraints to the table to be viewed. You can also manually select parts and pressing the middle top button finds the constraints attached to the selected part/s and shows these.
There are problems yet, several crashes, that I haven’t fixed. I also plan to get columns 1, 5 and 7 to toggle True/false so that constraints can be suppressed or parts fix for testing without having to open the property window but today I’m just. Just not smart enough.
Dan
PS: While looping through FreeCAD obj files sorting by 'ConstraintInfo' some mirror files slipped by. My machine? I could not find the cause.
mate cheker 2020-04-29.JPG (66.58 KiB) Viewed 1383 times
MateChecker 2020-02-29.FCMacro
(24.23 KiB) Downloaded 29 times
dan-miel
Postby dan-miel » Fri May 08, 2020 9:39 pm
kbwbe
I’m still trying to ease the pain when a part is changed and the mates blow up. I hope you have a moment to let me know how much trouble I‘m heading into by changing the mating parts in your constraints. I have 3 projects that I hope works together at some point.
You’ve seen the first that shakes the pile of parts to find lose ones.
The second that I’m just starting to think about is how to examine the differences before and after changes to try and find the entities that hasn’t changed to reconnect the mating parts. The attached picture shows a simple part that ca n be done by a human but they can get complicated quickly.
The third is to change the information in the constraint without destroying and creating a new constraint. I sometimes wonder if it will cause a stability problem further down the road. So far I have changed the information in constraint with but not the mirror. I know that you are busy but if you know problems that I will run into and could them put down in a few word them I would appreciate it.
Thanks
Dan Miel.
I know that these are not a fix but hopefully they will help.
Here is a 30 second video of changing constraint links. Every time I click on a surface the link's name is changed to the surface I clicked.[url]https://youtu.be/obgvMZYpVE4[/url
before and after.JPG (35.07 KiB) Viewed 1282 times
cobra18t
Postby cobra18t » Wed Jun 03, 2020 6:17 am
In V0.4.47, I have my units set to imperial and am trying to enter an offset in a coincident constraint. It defaults to mm, but it won't let me type "in" to define the units. How do I change units of offsets?
MRx
Postby MRx » Thu Jul 23, 2020 9:09 pm
When doing a check I get tons of messages:
It would be nice to get all those messages in a list and / or having the option to abort the check.
The root problem is actually rotating some objects were not rotated properly due to floating point issues it seems. After some chained up assembly the entire thing does not really match anymore due to those issues.
So I'm trying to delete some rules and it ends up in a mess of course (until I have things somewhat balanced again - "somewhat" because the assembly is not fully accurate)
Does anyone know how to get around that?
The bottom surface is aligned to the holder.
dan-miel
Postby dan-miel » Sun Jul 26, 2020 1:37 am
Welcome to FreeCAD Mrx. A2plus does have it's problems. I have tried to overcome some of them with third party programs with some of my ideas working better than others. problem 1: The message of "highlighted parts were not moved" is likely because you tried constraining two parts that are not constrained to the base fixed part. Problem 2: inaccuracies': I'm not sure what is not accurate in your screen shots. I do see that the one dimension is 153,1141 and the other is 133,1141. but it doesn't seem like it would be 20mm off. I wrote a program that reports the errors as a list and I had to set the precision to 5 places but that is still far from 20.
Dan
MRx
Postby MRx » Sun Jul 26, 2020 5:37 pm
I usually remove the constraints and update the objects. After that I'll re-apply the constraints (because just updating the objects doesn't seem to work properly - or in some cases I'm modifying the objects too much).
The problem is if you have a bigger design, there are too many of those popups.
Do you know about the freecad code? I think some kind of labelling the faces could help to fix the updating issues.
dan-miel
Postby dan-miel » Mon Jul 27, 2020 3:12 am
Unzip the file. Copy the directory to you "mod" directory and restart FreeCAD. Right click in the icon rows to add the new buttons to your customized dash.
You said the word "update", evil word. I'm attaching a work bench which consist of 4 programs. I've been told that the programs are too complicated and they are but I use every function so please bear with me. First the features of the part is numbered and when a part is changed, say a hole is added, the feature changes it name but the constraint doesn't change the name of that link so you end up with broken links. The update program tries to find the same feature or something close and reattaches the link. So next time you modify a file leave the constraints attached and update using the orange update button. To do this select the part that you modified and select update. Yes it only updates one part at a time. but I only modify one part at a time. It will also run the checker program with the green arrow automatically. If the update program could not find a feature a popup will state there are missing constraints and do you want to view them? Click yes and a dialog with a table will appear and the missing links will be yellow. This is the viewer. Clicking the constraint name column will highlight the two mating surfaces, if there were two surfaces but there is only one. Figure out where the missing surface goes and "click in the yellow cell" then click 'attach to' and select the feature you want to attach it to. And it should attach.
A long explanation but it only takes seconds to fix when it works. Try it a few times. To view all of the constraints from a part Click the lantern to open the viewer, select a part then click "Import from Part". All of the constraints will be loaded, or select some in the tree and click "Import from tree". Turn the assembly transparent to view the constraints. Also if you cannot find a feature then press the "find with label" button. Press it again to remove the label.
Dan
A2plusmore.zip
(201.76 KiB) Downloaded 29 times
MRx
Postby MRx » Mon Jul 27, 2020 4:03 am
Thanks for your work!
I'll download it later today and check it.
I absolutely understand your concerns about updating, I think this should be solved on a higher level allowing to attach the labels to an object (eg. explicitly adding a "Front" label to a Face)
I'm also refining the objects from time to time so it could be that some "selected" faces completely disappear from time to time. So why not attaching labelling support to the object structure directly.
I think you're working on the other end of FreeCAD.
I hope I did not misunderstood your post when you wrote about labels, did you mean faces?
Overall I'm quite happy with a2plus, just sometimes I run into tricky problems with it (which I was able to solve luckily).
Update 1:
I only downloaded it and had a look at the python code, seems like it's not so difficult to get into it, so I'll try to study the plugin within the next days.
One more thing, my workflow is that I assemble parts using a2plus but also design new parts based on the results of that assembly (eg. connectors to join 2 parts).
So I'm mixing a2plus objects and regular partdesign objects (the ones with the blue bricks).
As far as I've learned it's not possible to mix partdesign objects with a2plus objects, however it would still be valuable to be able to align surfaces of partdesign objects with a2plus objects (even without creating rules).
Currently I look at the coordinates and move such items manually.
Update 2:
it is possible to define rules for "Partdesign Objects" however they're placed outside of the object and cause weird issues (I remember I had those issues also when I started with a2plus). At that stage seems like I've nailed down all my issues.
Ok next step is to update a2plus here
dan-miel
Postby dan-miel » Mon Jul 27, 2020 9:50 am
I thought that any object can be assembled in A2+ Part design or not. All I use are part design.
A couple rules for the updater.
1 If all that you modify in your part is dimensions then use the standard updater. If you add or delete faces, add or delete holes, then use the one I sent you.
2 It might not like copied parts. I don't remember what it does I just remember that I added the arrays last.
Dan
