SolveSpace has been kept as python add-on also in A3 because of its license, GPL and not LGPL as FC would require to be directly included.
So probably you could get similar performances.
Thx
Thx
No problem if your are still using fc0.16. The workbench was designed for that. For fc0.17 i still have not tested. Will do that after rough finishing the WB.
When ready, it should be possible. Perhaps a little bit slow, since everything is programmed by pure python
You can try the "SAS" Button (SimpleAssemblyShape), which creates a single compound of the whole assenbly. You will find it then in the object tree. But do not really know wether a compound does work for 3D printing. It is not realy a solid i think. Simply do a test.
Unzip ZIP-archive. rename, if necessary the unzipped folder to "a2plus"
