MultiBody topdown modeling
m.cavallerin
Post by m.cavallerin »
Hi all,
I'm new to freeCAD.
I would like to investigate deeper the topic.
I'm looking for any help that can tell me how can I make a single (assembly) file containing the two bodies of another files, imported separately inside the Assembly2 environment. (see attachment)
As you can see on the graph dependency, the two parts contain one single body each and both of them are linked to a spreadsheet.
The goal I would like to achieve is the possibility to update each part inside the assembly WB (each derived from each single part of the master file) automatically, without any manual procedure, but only by clicking the update parts.
The main problem is that the Ass2 WB in order to import a file, needs only a single part highlighted.
Is there a solution?
Thanks for any help.
Michele
OS: Linux Mint 18.2 Sonya
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.12
OCC version: 7.2.0
tecnicaTopDown_skeleton.fcstd
(25.46 KiB) Downloaded 32 times
kbwbe
Re: MultiBody topdown modeling
Post by kbwbe »
@m.cavallerin
your problem is not really complicated. Your file contains two parts. This is not the way assembly2 is working at moment.
One part is a simple rod. Create a simple file only containing this rod.
Second part is some kind of level. Create a simple file only containing this level.
Create a new file. Use Assembly2, import and join these two parts with constraints and save the file. This new file will be a subassembly.
You can use the newly created subassembly file to be imported into a master assembly. (for your top down structure)
When changing your spreadsheet, save the affected raw parts again. Do updateImportParts in your subassembly file (rod+level) and save it.
You should have a then an updated subassembly. A master assembly has to be updated as next step.
Be aware: updating parts in assembly2 (not maintained at moment) is a critical process. Sometimes you have to reassemble it with setting constraints newly, because something goes wrong.
Best practice: do the supassemblies with really ready designed parts. Avoid to change them to often. This will save a lot of work.
Hope this helps,
kbwbe
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
m.cavallerin
....This is not the way assembly2 is working at moment.
thx in any case, I'll consider the other way of proceeding.
Regards.
kbwbe
Post by kbwbe »
I think i will allow multibody import within my new workbench A2lus next time. It makes sense for small subassemblies.
KBWBE
Jee-Bee
Post by Jee-Bee »
kbwbe wrote: Thu Jun 28, 2018 8:26 am It makes sense for small subassemblies.
I would say "It makes sense for subassemblies."or better ;) "It makes sense."
kbwbe
Post by kbwbe »
@Jee-Bee
Absolute correct ! Sounds better ;)
KBWBE
