Assembly 3 - Bug on selecting faces in 3D objects of the same instance
cyberlacs
Post by cyberlacs »
I developed some 3D objects where I succeeded in all modeling, perfect what FreeCAD does.
Now I'm trying to perform the assembly, but I'm having difficulty with Assembly 3
Bug detected.
If I insert the same 3D object in my assembly set several times, example
PPS.001
PPS.002
PPS.003
When I select a face of the 3D object PPS.001 and try to select with CRTL the same face of PPS.002 and PPS.003, Assembly 3 does not allow selection.
Conclusion
I think because it is an instance projected in the screen of Part Design or Part the Assembly interprets that when selecting a face of PPS.001 when I will select the one of PPS.002 and PPS.003 Assembly 3 in its codification translates as face already selected .
Attached image just below
fosselius
Re: Assembly 3 - Bug on selecting faces in 3D objects of the same instance
Post by fosselius »
I am afraid i cant repeat this. are you using 0.8?
I have tried:
selection of object1
selection of object1_copy Inside Asm/Parts
selection of object1_link
selection of object1_link inside Part
selection of object1_copy inside Part
selection of object1_link inside Part in assembly/Parts
selection of object1_copy inside Part in assembly/Parts
selection of object1_external_link
selection of object1_external_link inside Asm/Parts
Screenshot from 2018-08-07 18-51-21.png (105.89 KiB) Viewed 1044 times
test2.fcstd
(13.51 KiB) Downloaded 55 times
test1.fcstd
(53.73 KiB) Downloaded 38 times
fosselius
Post by fosselius »
Improved a bit to also cover sub-assemblies
pad (unable to move pad as it is not in an container)
body - pad
part - body - pad
Link/pad
Link/body - pad
Link/part - body - pad
assembly - pad (unable to move pad as it is not in an container, rendered at same position as pad above)
assembly - body - pad
assembly - part - body - pad
assembly - assembly - pad
assembly - assembly - body - pad
assembly - assembly - part - body - pad
Screenshot from 2018-08-07 19-13-18.png (87.81 KiB) Viewed 1039 times
test2.fcstd
(33.45 KiB) Downloaded 40 times
test1.fcstd
(140.98 KiB) Downloaded 44 times
cyberlacs
Post by cyberlacs »
Before the post of a new release, I was using this release. https://github.com/realthunder/FreeCAD_ ... 3/releases
Preview 0.7, 2018.06.30
And this up was giving the bug described.
But after the announcement of a new version, it works perfectly. https://forum.freecadweb.org/viewtopic.php?f=20&t=25712
Preview 0.8, 2018.08.07
In assemblies with Assembly 3 I perceive a great slowness
In assemblies when I use the Move Part feature to test assembly movements it is very slow
ceremcem
Post by ceremcem »
Would you consider marking this as Solved?
