Hello there ,
Testing assebmly3 I am unable to create an origin / workplane in the assembly as define in the wiki
I use assembly3 0.8.1
OS: DebianEdu/Skolelinux
Version: 0.17.5235 (Git shallow) AppImage
Build type: None
Branch: LinkStage3
Hash: ccaa87e12aaadbd3106607fc503542a863b742da
Python version: 2.7.6
Qt version: 4.8.6
Locale: French/France (fr_FR)
Normal, or misuse from me?
Assembly3 - Origin and Workplane
Re: Assembly3 - Origin and Workplane
Can you do this in Assembly2?
works fine for me, i have built it from the latest on LinkStage3 & asm3:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14897 (Git)
Build type: Unknown
Branch: LinkStage3
Hash: 4c976717c0e15e804a92354c00a115bcb6f85ed9
Python version: 2.7.15rc1
Build type: Unknown
Branch: LinkStage3
Also tested with the 0.8.1 appimage, it worked fine for me..
I also tested to do the exact same button / save sequence as you, with auto solve on, the only difference i can spot is locale and it should not have any impact.
Build type: None
Branch: LinkStage3
Qt version: 4.8.6
Build type: None
Branch: LinkStage3
Qt version: 4.8.6
Ok,
so I switch to EN and it worked.... back to French it worked..... quite strange.
I'll try to see if it can come from another things I've done.
before recording the GIF file I had a File opened and it was not working in this one. Now it works.
I tried several times with freecad restart and even with computer reboot (for other reason) but I was thinking I was not doing things correctly and it was not working so it is not a one shot problem.
Just think about something.
I'm using an appimage on debian with :
to start Freecad.
maybe somthing related here
LIBGL_DRI3_DISABLE=true
