So, first of all thanks again for the ASM3, that is an impressive work... and it work great!realthunder wrote: ↑ ping
As explain in a previous post, I wanted to share an idea about the UI of assembly3. I didn't put it in the open discussion assuming that there is maybe not a lot of users of Assembly3, and I don't want to confuse newcomers, making them thought that this workbench is already in the main release.
If it is a bad idea, mods, don't hesitate to move the topic.
so here my 2 cts :
When dealing with large assembly, the tree is a little bit complicated to manage. My main concern is to locate constraint involving one part. The only possibility today is to label the constraints with clear name to indicate which parts are involved.
A first interesting solution would be to have the possibility to group constraint in a folder.
so if we have constraint involving a function we could group them as we wanted.
another solution could be to have automatic group by part, as in the image below.
so the same constraint appear within the 2 parts involved. This solution will not reduce the size of the tree but may help quickly identify a constraint, specially when design update are done in a part, and need to re-define elements.
Of course only the main root of the part would be shown, not all the feature as it is already available in the part section.
Looking at CATIA image shows that by default name of the parts is between bracket in the name of the constraints. So Basically it will may also ends with large tree in the case of large assembly. I don't think it is possible to group it. In NX I think there is a specific tab for constraint (constraint navigator), and you can navigate by part (which is what I had is mind indeed), or by other status.
From What I remember, Solidworks is quite close to CATIA on this (but I'm sure some of you know it better then me and may correct me if I'm wrong)
