assembly without solver
Zolko
Re: assembly without solver
Post by Zolko »
Nice. I've managed to port some of the macros over to the WB, I'll upload them in an hour. Not all though yet
emills2
Post by emills2 »
activeDoc is defined at line 42, part of
def Activated(self)
so it is local to Activated()
then you call it at line 113, as part of
def getAllParts(self)
getAllParts() is itself called within Activated(), AFTER you declare activeDoc = FreeCAD.ActiveDocument, BUT you changed function level! and you did not specifically pass activeDoc. you passed self.
i changed line 48, and passed a parameter
		self.getAllParts(activeDoc)
amd i changed the corresponding definition on line 109 to receive the parameter
	def getAllParts(self,activeDoc):
the error went away from the report view, but still an empty window. did you see the same error from my previous post?
emills2
Post by emills2 »
after looking through a little bit more, i figure your style would probably be more like
line 42
		self.activeDoc = FreeCAD.ActiveDocument
line 109
	def getAllParts(self):
and line 113
			if doc != self.activeDoc:
still looking for the actual problem. i haven't played with the custom windows before, so this is interesting, even you have it all sorted out already.
Zolko
Post by Zolko »
emills2 wrote: Tue Feb 19, 2019 8:18 am after looking through a little bit more, i figure your style would probably be more like
my coding "style" ... that's a good one.
Well, I managed to make the workbench work on my computer. There are still warnings, but so far all works as expected ... by me. That is, as soon as other people will try, it'll break. And then, I'd like to fix it, to bring this workbench / framework to a usable state for the average Joe, and then we can extend it with fancier features. Version 0.2 of this workbench can be found on:
https://github.com/Zolko-123/FreeCAD_aw ... 4_v0.2.zip
To be extracted into ~/.FreeCAD/Mod
emills2
Post by emills2 »
doesn't seem to want to load the workbench
'module' object has no attribute 'PrintWarning'
File "<string>", line 47, in Initialize
this one is pretty baffling. 'PrintWarning' dosen't seem to exist anywhere in your files :lol:
emills2
Post by emills2 »
InitGui.py: i switched the contents of Activated and Initialize (by simply changing the function name in the definition).
the workbench now loads. on my machine at least, you cannot pass on Initialize. you can pass on Activated.
	def Activated(self):
		#self.appendMenu(["&Edit","DynamicData"],self.list) # appends a submenu to an existing menu
		pass
    ║                      Menu                     ║
    def showMenu(self):
        from PySide import QtGui
        window = QtGui.QApplication.activeWindow()
        #freecad hides wb toolbars on leaving wb, we unhide ours here to keep it around
        #if the user has it set in parameters to do so
        pg = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Assembly4")
        keep = pg.GetBool('KeepToolbar',True)
        if not keep:
            return
        tb = window.findChildren(QtGui.QToolBar)
        for bar in tb:
            if "Assembly 4" in bar.objectName():
                bar.setVisible(True)
    ║          Standard necessary functions         ║
    def Initialize(self):
        "This function is executed when the workbench is activated"
        import newModelCmd     # creates a new App::Part container called 'Model'
        import newSketchCmd    # creates a new Sketch in 'Model'
        import newLCSCmd       # creates a new LCS in 'Model'
        import newBodyCmd      # creates a new Body in 'Model
        import insertLinkCmd   # inserts an App::Link to a 'Model' in another file
        import placeLinkCmd    # places a linked part by snapping LCS (in the Part and in the Assembly)
        import placeLCSCmd     # places an LCS relative to an external file (creates a local attached copy)
        #self.list = ["newModelCmd", "placeLinkCmd", "DynamicDataAddProperty", "DynamicDataRemoveProperty", "DynamicDataImportNamedConstraints","DynamicDataCopyProperty","DynamicDataSettings"] # A list of command names created in the line above
        self.listCmd =           [ "newModelCmd", "newSketchCmd", "newLCSCmd", "newBodyCmd", "insertLinkCmd", "placeLinkCmd", "placeLCSCmd" ] # A list of command names created in the line above
        self.itemsMenu =         [ "newModelCmd", "newSketchCmd", "newLCSCmd", "newBodyCmd", "insertLinkCmd", "placeLinkCmd", "placeLCSCmd" ] # A list of command names created in the line above
        self.itemsToolbar =      [ "newModelCmd", "newSketchCmd", "newLCSCmd", "newBodyCmd", "insertLinkCmd", "placeLinkCmd", "placeLCSCmd" ] # A list of command names created in the line above
        self.itemsContextMenu =  [ "placeLinkCmd", "placeLCSCmd" ] # A list of command names created in the line above
        self.appendToolbar("Assembly 4",self.itemsToolbar) # leave settings off toolbar
        self.appendMenu("&Assembly",self.itemsMenu) # creates a new menu
        return
ok! now i'm going to try to do something.
emills2
Post by emills2 »
ok, now i'm back to where i was previously. good.
i built the same 2 parts, 3 instances assembly as before, edited the LCS sketch, got the live update.
i deleted the linked parts, the corresponding constraints are still in the folder. is there a some kind of "OnDelete()" available to deal with this?
i readded the parts, without carefully creating unique labels, and it renamed the second instance by itself, and the constraint followed! excellent. i placed the links, and each tracks individually. good stuff!
gotta wait til next weekend to try much more.
i'm not sure what 'attach an LCS to an external part' is all about.
Zolko
Post by Zolko »
emills2 wrote: Wed Feb 20, 2019 4:59 am 'module' object has no attribute 'PrintWarning'
yeah, I don't know what that is. So I went back to v0.1 and forward-ported the commands from v0.2. That makes the v0.3. This one loads and works on my computer ... but so did v0.2 before uploading. I created an Assembly 4 repository, but I don't know how to use it
emills2 wrote: Wed Feb 20, 2019 5:50 am i deleted the linked parts, the corresponding constraints are still in the folder. is there a some kind of "OnDelete()" available to deal with this?
hum, I dunno now, must check
yes, that was important, and I got it from your scripts
nested assemblies. Assembly in an assembly inside another assembly. It's the next workshop
Zolko
Post by Zolko »
In this image, there are ~300 parts, in sub-assemblies and sub-sub-assemblies, of ~10 different types. This assembly structure allows to make really really large assemblies now. A 4x2 brick is 432Kb, the entire assembly just 30Kb ! But the fact that each included part has an open window begins to be problematic.
emills2
Post by emills2 »
Zolko wrote: Wed Feb 20, 2019 8:56 am but I don't know how to use it
i never do anything more complicated than shown here actually usually much less complicated:
http://rogerdudler.github.io/git-guide/
creating a local git folder and cloning a github repo i only did once or twice. wasn't hard, but can't remember clearly. i don't use the fancy github GUI tool, but they also give you a "Git Shell". which is awesome because it give me a good unix shell on windows
in practice, day to day looks like this
cd ~
cd ./AppData/Roaming/FreeCAD/Mod/Silk (get to my git folder)
git status (shows me how many files i changed, in red)
git add --all (i basically always add all my changes)
git status (shows me how many files i added to the 'queue', now in green)
git commit -m 'mandatory commit message' (i actually have to type in something here)
git status (shows me all changes are taken care of)
git push origin master ('push' all commits to github)
if i actually did something through the website, like accept soemone's contribution, then i
git pull
that's it.
in Git Shell on windows, i just pull all the commands from history, and only type the message.
