Making planes visible in assembly?
Deadhorse
Postby Deadhorse » Thu Dec 20, 2018 4:42 pm
Is there a way to make datum planes, original or user created, visible in assembly mode/work bench?
kbwbe
Re: Making planes visible in assembly?
Postby kbwbe » Thu Dec 20, 2018 5:08 pm
Not possible. They are filtered out during import, as they would not work correctly.
KBWBE
latest release: v0.4.47f, installable via FreeCAD's addon manager
dan-miel
Postby dan-miel » Thu Dec 20, 2018 8:31 pm
A possible work around. The first part put into to assembly seems to be inserted at global xyz. I have a "template" with surfaces at xyz so I can tell where it is. Then work off of that corner of your part. You could put in a dummy part and hide it.
Dan
triplus
Postby triplus » Fri Dec 21, 2018 11:10 am
ATM only Assembly 3:
https://forum.freecadweb.org/viewtopic. ... 85#p203685
