I've heard some good work in Assembly 3.
I just wonder whether loose and interference fit modelling will be supported in Assembly 3?
If not, then do we have allowance in the current data structure so that disruptive data structure changes are not required if such support were to be implemented in the future?
Loose and interference fit modelling in Assembly3
Re: Loose and interference fit modelling in Assembly3
Could you please be more specific? What do you mean by "loose and interference fit modelling"? Googling gave me no results which makes sense.
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
Sounds like bolean operation with a modifier to me?
I know the "hole tool" have tight or loose fit as options. Is it something like that?
Only thing i can think of... are sliders etc.
So you have some (limited) degree of freedom.
This is something to consider when you want to put in a pin or a press-in something.
