Error message with A2P topology naming
WayofWood
Postby WayofWood » Tue Jan 01, 2019 7:36 pm
When I try to import the attached file in a new assembly the module throws an error message:
Running the Python command 'a2p_ImportPart' failed:
  File "/home/olf/.FreeCAD/Mod/A2plus/a2p_importpart.py", line 275, in Activated
    importedObject = importPartFromFile(doc, filename)
  File "/home/olf/.FreeCAD/Mod/A2plus/a2p_importpart.py", line 199, in importPartFromFile
    withColor=True
  File "/home/olf/.FreeCAD/Mod/A2plus/a2p_MuxAssembly.py", line 103, in muxAssemblyWithTopoNames
    newName = "".join((vertexNames[i],obj.Name,';'))
list index out of range
Any help appreciated.
In general should I rather post this kind of error message in the forum or should I post it to the bug tracker?
Best regards
Oliver
OS: Ubuntu 16.04.5 LTS
Version: 0.17.13541 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.12
tn_base_table_frame_with_supports.fcstd
(378.88 KiB) Downloaded 16 times
Turro75
Re: Error message with A2P topology naming
Postby Turro75 » Tue Jan 01, 2019 8:15 pm
no issues on my side, I tried both opening and importing it in another assembly.
A2plus updated just before the test
my setup:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.13712 (Git)
Build type: None
Hash: 57b7f3389a846454d01c2abea509b8394099735c
Python version: 2.7.14
OCC version: 7.2.0
Locale: Italian/Italy (it_IT)
kbwbe
Postby kbwbe » Tue Jan 01, 2019 8:29 pm
    withColor=True
I confirm, error occures with toponaming enabled. I will have a look.
P.S. the subassembly "tn_base_table_frame_001" causes this error. Please post the subassembly and sourcefiles for this.
KBWBE
latest release: v0.4.42b, installable via FreeCAD's addon manager
WayofWood
Postby WayofWood » Tue Jan 01, 2019 8:55 pm
Thanks a lot. Please find the missing file attached. I also attached the sub-sub-assemblies and the parts - although not 100% sure if I got everything.
Best regards
Oliver
base_table_y_beam_i_profile_120x40_heavy.fcstd
(153.37 KiB) Downloaded 15 times
base_table_x_support_i_profile_80x40_heavy.fcstd
(243.59 KiB) Downloaded 12 times
base_table_x_beam_i_profile_120x40_heavy.fcstd
(109 KiB) Downloaded 12 times
tn_base_table_half_frame.fcstd
(104.11 KiB) Downloaded 13 times
tn_base_table_frame.fcstd
(211.19 KiB) Downloaded 12 times
kbwbe
Postby kbwbe » Tue Jan 01, 2019 9:46 pm
Hi Oliver,
i just assembled the frame and the support newly (toponaming enabled). The resulting assembly can be imported to next level assembly. Very strange.
I worked with recent master version.
Please find my assembly attached and try to import it to next level assembly.
assy.FCStd
(349.78 KiB) Downloaded 17 times
KBWBE
WayofWood
Postby WayofWood » Wed Jan 02, 2019 6:58 am
Thanks a lot. I will be traveling for a few days and work with with your version as soon as I‘m back.
Best regards
Oliver
