Current Assembly Status
catman
Re: Current Assembly Status
Postby catman » Mon Feb 17, 2020 9:14 pm
Can you please update the status for Assembly3
It is now available for testing as part of the Linux AppImage (and I believe DMG) in the current development version pre_0.19 from here: https://github.com/FreeCAD/FreeCAD/rele ... 4.AppImage. That means the Asm3 functions can be tested without the special build from realthunder.
Reference: https://forum.freecadweb.org/viewtopic. ... 68#p366768
Alexer
Postby Alexer » Sun Aug 30, 2020 9:23 am
Hello everyone, I am a CAD / CAE technician and I am positively impressed with your work.
I believe that the ASSEMBLY section is fundamental for mechanical design and so far the Assembly 3 project seems to me the most suitable and complete one. Let me just ask you if it is possible for you to implement:
- the possibility to modify the piece directly in the assembly;
- the possibility of making sections directly in the assembly;
- a measuring tool to check the various distances / surfaces / volumes: in case of modifications, make sure not to waste too much time.
I absolutely thank you for your attention.
jpg87
Postby jpg87 » Wed Sep 02, 2020 12:25 pm
Hello, welcome to the forum!
Yes, just double click on the link name:
Yes with the tool:
Yes at least with these tools:
My website : http://help-freecad-jpg87.fr updated 2020/05/10
DaAwesomeP
Postby DaAwesomeP » Tue Sep 15, 2020 5:26 pm
Hello! I am getting started with assembly in FreeCAD. I am just working on personal projects, but I want to be sure my files are as future-proofed as possible in case I open them again in a few years. I also want to be sure I learn to use whatever is most likely to become the "standard" over time. It sounds like I should try out Assembly3 on 0.19?
Thanks!
Postby chrisb » Tue Sep 15, 2020 5:34 pm
We don't know what and how the satndard will be. The most future safe Assembly workbench is probbaly Assembly4, because it doesn't rely very much on external things.
