Assembly 4 workbench
Zivatar
Re: Assembly 4 workbench
Postby Zivatar » Thu Nov 12, 2020 9:33 pm
Zolko wrote:
Thu Nov 12, 2020 8:50 pm
Thank-you for your kind words. But I have the impression that you place a Body inside an Asm4 Model : is there a particular reason to do so ?
Yes, you are right. The rason is I tried to follow this tutorial: https://www.youtube.com/watch?v=n04M6nFvdxs I thought that is normal.
However it is now clear I need to understand more about the concept, can you suggest where can I find the most extensive description (I know about the base documentation). My aim is to keep parametric as far as I can.
Using an Asm4 Model is mandatory for assemblies, not parts.
Thank You! I will take care about it!
You can do that in a non-parametric way: in the Part WB, you convert your linked part to solid (Menu > Part > Convert to solid), then you copy this solid to the document where your cylinder is, and use boolean operation on the cylinder.
But I don't know whether it's possible to do it and keep the parametric design.
Thank You, that is very useful hint for me!
Kind Regards,
Tivadar
topyra
Postby topyra » Thu Nov 12, 2020 10:51 pm
Hi all - it is my first post here :)
I would like to create an axis that would go from one part in model to another part.
Each part is positioned by different LCS.
In attached example
link.FCStd
(35.74 KiB) Downloaded 19 times
there is an Axis_1 that I intended to go from Tube001.Edge5 (far end of bottom arm) to Tube002.Edge5 (top mount).
But unfortunately I am not able to do this - axle do not go thru end of bottom arm (Link001).
I would like to position two remaining parts (cyl_big, cyl_small) along this axis (one with orign at top, other at the bottom) - to model hydraulic cylinder between that two parts.
I want this hydraulic cylinder to animate according to changing 'angle' variable that move
I think may be similar problem to @goopypanther (if I understand him correctly).
Because I am very beginner, maybe I am doing everything wrong - if so, please give me some hints how to calculate LCS's for cyl_big and cyl_small to put it between center of Tube001 (Link001) and Tube002 (Base001).
Thanks
OS: Ubuntu 20.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22960 (Git) AppImage
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
goopypanther
Postby goopypanther » Fri Nov 13, 2020 12:11 am
Ohhhhh now this is making sense, I learned from the same tutorial. Haha, sorry for the confusion Zolko.
Zolko
Postby Zolko » Sun Nov 15, 2020 12:55 am
Hello,
a new version (v0.9.11) of the Assembly 4 workbench is out: thanks to great help from others, the link placement dialog is vastly improved, and there is now a configuration engine. The combination of the 2 makes it very easy to build exploded assemblies.
Zivatar
Postby Zivatar » Sun Nov 15, 2020 9:51 am
Great!!! Thank You
HK sxx
Postby HK sxx » Sun Nov 15, 2020 2:33 pm
Hello,
When adding a variable, typing its name, with each character pressed it throws an error in the report view
    File "C:\Users\HK\AppData\Roaming\FreeCAD\Mod\Assembly4\VariablesLib.py", line 145, in onNameEdited
      pattern = re.compile("^[A-Za-z][_A-Za-z0-9]*$")
  NameError: name 're' is not defined
It can be ignored, it doesn't seem to affect anything. I'm telling you this for your information only, in case you didn't know.
With the 0.9.9 version it did not happen.
OS: Windows 10 (10.0)
Version: 0.19.22988 (Git)
Hash: cdc01cb20cfa74079c45b9dc2dab81e3248b2aa5
Python version: 3.6.8
Qt version: 5.12.1
Locale: Spanish/Spain (es_ES)
Zolko
Postby Zolko » Sun Nov 15, 2020 2:55 pm
When adding a variable, typing its name, with each character pressed it throws an error in the report view ... With the 0.9.9 version it did not happen.
Thank-you for the report. This is PR #106 and I don't know what it does. On Ubuntu it doesn't do anything ....
EDIT: oups, it's a Regular Expression, and needs an
import re
Fixed, I update, thank-you for the catch
EDIT 2: I pushed the update, can you please check ?
HK sxx
Postby HK sxx » Sun Nov 15, 2020 3:21 pm
It is tested. Now no error appears.
Thank you.
ppemawm
Postby ppemawm » Sun Nov 15, 2020 5:54 pm
a new version (v0.9.11) of the Assembly 4 workbench is out the link placement dialog is vastly improved...and there is now a configuration engine. The combination of the 2 makes it very easy to build exploded assemblies.
Thank you for the excellent enhancements.
I have already begun using the new version in my current project https://forum.freecadweb.org/viewtopic. ... 60#p448228. It works as expected after I discovered the save and restore in the right-click Assembly dialog which I quickly added to my Assembly4 custom toolbar along with the handy "show LCS..." button.
If I understand correctly you cannot explode a part in the sub-assembly link in the top-assembly file but must do it in the sub-assembly file? I suppose that a limitation of the link function.
Zolko
Postby Zolko » Sun Nov 15, 2020 6:08 pm
yes, I've seen your project, impressive as usual. Did you see that the configuration also stores hide/show values of objects ? It doesn't (yet) explode fasteners, I have to add them
yes, that's an App::Link limitation. It might be solvable with variant links ...
