Many thanks! It works fine.
Assembly 4 workbench
Re: Assembly 4 workbench
Thanks for the latest revisions. Much improved usability.
"It is a poor workman who blames his tools..."
Feature Request:
Would it be possible to add a mode, where all the sub- and sub-sub-etc-part LCS:s would be hidden in the 3D view? If I understand correctly, it is only possible to link between LCS:s in the current file's Model folder and directly attached Bodies' and Parts' LCS:s. Thus, I'd like to avoid cluttering the 3D display from subsub...part LCS:s, that are inaccessible from the current file anyway. Not sure, if this kind of hiding is technically feasible or even possible, though...
Maybe it would be easier to say that I would like the 3D view to only show LCS:s that are directly accessible from the current file by Asm 4. BTW, Assembly 4 is a great tool, I use it all the time, thanks!
- dcapeletti
Hi, I have a question. When I import a part into Assembly4, I would like to know if two or more restrictions can be applied at the same time.
Imagine that with one point the parts are centered but there is 360º mobility in all axes, if you put a reference line and a point or three points then the parts only have one placement. Is this possible? Apply more than one constraint to the part.
Thanks
Thanks
Hi, Asm4 is an assembly workbench without solver, that is the main idea behind the workbench. So, no, it's not possible. However, you're supposed to a do a skeleton sketch (a sketch without any 3D-shape, just the sketch), and use the sketch solver. There you can apply multiple restrictions, albeit in 2D-only. Then, you'll attach the LCS:s into some sketch elements, and voila, your assembly follows the sketch movement. This allows neat animations by animating the sketches. Moreover, you'll be able to combine several 2D sketches in order to do 3D solving/animation, if necessary.dcapeletti wrote: ↑Sat Jul 04, 2020 4:16 pm Hi, I have a question. When I import a part into Assembly4, I would like to know if two or more restrictions can be applied at the same time.
EDIT: I made a small example assembly, just for fun! If you load the attached FCStd model, and activate the Asm4 workbench and hit the animate icon (the two gears), and fill in the Arm_angle as animated variable and range from e.g. 0 to 60 with 0.5 steps, you'll see a sketch based simple animation. The model is real simple, so it should be rather easy to study how it's done. The main difficulty is to hit the small blue (f(x)) button in Master Sketch Constraints, which is needed in order to put variables into the sketch constraint values. Hitting the button opens a small window, where you'll write "Variables.my_variable" (without the quotes).
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.21854 (Git)
Build type: Unknown
Hash: ffbcab5b4964af1170e7f09e9788b3ade0c727af
Python version: 3.8.3
Qt version: 5.14.2
OCC version: 7.4.0
- 20200705 Asm4 Animation.FCStd
- (68.4 KiB) Downloaded 73 times
I want to do Nested Assembly, and I can add New LCS directly on Model, but when I edit datum and select anything, it says problem in selection on report view, how can I solve this?
I don't get the same error message but I can't select any element of one of the subassemblies in order to reference the LCS of the Model.
When I select a line or a surface the task list does not react by adjusting the options to choose and when hitting ok it tells me that no reference has been selected.
Best regards
Oliver
Can you please list the exact steps you do to get to the problem ?
It seems to me that you try to attach a datum object with the "Edit Datum" command (right-click > Edit Datum), which is the same as hitting the small [...] button in the MapMode field of the object's properties, and then try to attach the datum to something in a child link of the assembly. Is that right ? In which case this behaviour is "normal" in the sense that this doesn't work like this. Attachment to App::Link objects is not supported (currently at v0.19).
What you have to do is to create and attach a datum object in the document where the original (linked) object is. If you want to have that datum in the assembly, then you need, after having created and attached the datum in the original object, to "import" it into the assembly, which does the following: it creates another (native) datum in the assembly, and attaches it to the original datum in the original object. Thus, the datum in the assembly will always "follow" the original datum in the original object. But there are actually 2 distinct datum objects: 1 in the original (linked) file and 1 in the assembly.
Hi Zolko,
thanks for the reply. It might also be that I am using the Assembly 4 workbench the wrong way. Therefore let me first describe what I would like to achieve and then go step-by-step through the challenges with a simpler example.
This is a a simple Item Cross-Brace that I have put together from an Item profile and two connectors as an assembly. I would now like to place this assembly at several places in a bigger one:
For this I thought the logical approach would be to define a LCS within the assembly of the Crossbrace so that I can attach this LCS to elements in the overall assembly.
Here are the steps for reproducing my problem:
1. Working with FreeCA 0.19 and a recent (1 week old?) version of A4:
2. Creating a New Part, Body, Sketch, Padding it to a cube and adding an arbitrary LCS (see file cube)
3. Creating a New Model in a separate file, adding the cube part twice and attaching one cube to another (see file 2cubes)
4. Now I would like to add a LCS "LCS_in_Model" to the model that I could then use to place the subassembly of the two cubes (or my crossbrace in reality) into a bigger assembly. After adding the LCS, I edit it but I can't select a reference (neither a plane, vertice, edge, nor a LCS from one of the parts:
Would be great if you could let me know what I would have to do differently. Thanks a lot in advance!
Best
Oliver
OS: Ubuntu 20.04 LTS
Version: 0.19.21718 (Git) AppImage
Hash: 002e25b5617f2c79f65968f1f82f7267899965c3
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Best
Oliver
- cube.FCStd
- (11.82 KiB) Downloaded 94 times
- 2cubes.FCStd
- (6.2 KiB) Downloaded 50 times
