The resulting numbers seem kinda right, but it's hard to know to sure. I guess I should be experimenting with a far simpler hierarchical model where I can calculate the center of mass by hand and compare the result.
I'm kinda back to the party, until the next Covid wave hits my plans again...
Is there any documentation for mention of the new features/buttons/commands to catch up?
a BIG update: version 0.10 is out today, whit many fixes and (hopefully) improvements. It uses the newly discussed assembly file format (here) and custom objects for the WB. There is now also some support for translations (although I don't know how that works) and some files are re-organised.
My goal was to have this out for the new Debian Bullseye, we're a week late, sorry.
This was actually very helpful, I used their model to test the new version: it should be 100% compatible with existing models, if you encounter problems please report.
Next steps should be:
part info (ideally from template)
BoM and CoG (it's the same algorithm: parse the tree and keep note of what is encountered)
project4 wrote: ↑Mon Aug 23, 2021 7:00 pm
is it backward compatible with old files format?
Or everything have to be re-built from scratch?
it should be 100% compatible, if it's not it's a bug and please report
Also, do you know what is the status of the links problems when files are moved between different computers that have different paths?
I've seen that sometimes files are saved as *.FCStd and sometimes as *.fcstd. This is then a killer for a project, but this is a FreeCAD bug and needs to be fixed urgently. If you have reliable info please report it in the "Open Discussion" forum
I've updated to last version.
Get my freecad freeze in the "Place linked part" dialog.
Killing the application is the only way out of it.
Anyone experiencing something similar?
Don't know if it's somehow related to my files.
Also, Zolko, I see the long awaited translation and rotation buttons in that dialog (I know you added them long ago and it's not related to 0.1 version).
But it looks like the view is not updating when linking a new part.
Pressing the buttons seems to update the data, sice after I press OK, the part will appear in proper position.
When I use the same dialog to update existing part attacjment, the view will update on any click of the buttons.
I mostly tried the rotation, not sure about the translation.
When I make my LCS(s) in the part, I usually hide them after (to free up space for view). After, when I put a part to an assembly - Asm4 unhides the LCS(s) which I use for connections - that's good. But when I finish adding parts - all the LCS(s) are unhided and I need to hide them again. Is there any way to unhide the LCS(s) in the assembly only for connection time (when the dialog of arranging parts ("Place linked Part") is open) and hide them back automatically when we finish with LCS settings?
And one rule idea for visibility of LCS(s): if the part has some combination of hidden and visible LCS(s) - Asm4 keeps them as they were in original part file before the "Place linked Part" dialog was opened?
