Assembly 4 workbench
Re: Assembly 4 workbench
I found the solution. If I use one of these two commands to place/insert the coordinate system then it works:
a) "MenuText": "Edit Attachment of a Datum object", "ToolTip": "Attach a Datum object in the assembly to a Datum in a linked Part" (placeDatumCmd.py) or
b) "MenuText": "Import Datum object", "ToolTip": "Imports the selected Datum object from a linked Part into the assembly.\nOnly datum objects at the root of the linked part can be imported" (importDatumCmd.py)
My problem was that I always used the "Edit Datum" from the context menu of a Datum object in the tree view.
(Which python file contains the source code of this "Edit Datum" context menu?)
Hello!
I've been trying to follow the tutorials for assembly 4 workbench and I'm running into an issue where I can't select the edge to act as a reference on the bearing for the LCS per the tutorial. However I can clearly see in the accompanying video that you can select edges in the imported model. The exact step I'm referring to is https://github.com/Zolko-123/FreeCAD_Ex ... te-systems
I'm not sure if this is an issue with the bearing stp file, if it's some import settings or if it's a bug with the version of FreeCad I'm running. I couldn't find anything on the FreeCAD bug tracker regarding imported stp files as well. The FreeCAD version details are
I'd appreciate any tips on what I'm doing wrong here, thanks!OS: Windows 10 (10.0)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/New Zealand (en_NZ)
You must be in the Part where the edge ans LCS are, and where you want to do the attachment. You cannot do that in the assembly with the already imported model. In other words, you must be in the Bearing document. To avoid confusion, I always work in the "Single document" mode (where the tree only shows the active document), and avoid whenever possible the "Multi Document" mode (where the tree shows all open documents, and you never know in which is the working document).cryuji wrote: ↑Sun Apr 12, 2020 8:42 am I've been trying to follow the tutorials for assembly 4 workbench and I'm running into an issue where I can't select the edge to act as a reference on the bearing for the LCS per the tutorial. However I can clearly see in the accompanying video that you can select edges in the imported model.
Ah, thanks for the tip, although it didn't solve my issue completely. I ended having to reset my settings before it worked as expected - I guess some old settings or settings from previous versions of FreeCAD were causing some weird behaviour.Zolko wrote: ↑Sun Apr 12, 2020 3:50 pmYou must be in the Part where the edge ans LCS are, and where you want to do the attachment. You cannot do that in the assembly with the already imported model. In other words, you must be in the Bearing document. To avoid confusion, I always work in the "Single document" mode (where the tree only shows the active document), and avoid whenever possible the "Multi Document" mode (where the tree shows all open documents, and you never know in which is the working document).cryuji wrote: ↑Sun Apr 12, 2020 8:42 am I've been trying to follow the tutorials for assembly 4 workbench and I'm running into an issue where I can't select the edge to act as a reference on the bearing for the LCS per the tutorial. However I can clearly see in the accompanying video that you can select edges in the imported model.
So I am now comfortable with the "basics" of A4.
My question is: "Can multiple sub assemblies be built is a single document? If so how? If not, how would you reference a single spreadsheet containing the system constants and their values over multiple documents?"
I have read both the Assembly4 "User Instructions" and "Tech Manual", but neither addressed whether or not assemblies of assemblies could be done within a single document.
Current situation
I am designing a display case that will also have drawer type storage in its base portion. I wish to design this as a series of sub-assemblies both for design organization and for improved workflow in a one person shop. The intended sub-assemblies are:
The Specs
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.Unknown
Python version: 3.6.5
Qt version: 5.9.7
OCC version: 7.4.0
Current situation
- Baseboard frame
- Cabinet Base Assembly
Base Carcass
Drawer Housing Assembly
-- Drawer Support Panels
-- Drawer Slides
-- Drawers Assemblies - 4" and 6" - Crown (crown molding and roof)
The Specs
Qt version: 5.9.7
OCC version: 7.4.0
- Wall Unit.FCStd
- (549.81 KiB) Downloaded 41 times
Sincerely,
Michael S. Olsen
Electrical Engineer & Joiner
Michael S. Olsen
no, there can only be 1 Assembly 4 Model per file (document). This is documented somewhere I think.
with a Master Part: you create a new document called MasterPart, create there an Asm 4 Model, set your variables, and you include (per Asm4) this Master Part in all your documents where you need to use those variables. The Variables can be accessed by the ExpressionEngine "MasterPart#Variables.Length" ... should work with a spreadsheet also, but I never triedIf not, how would you reference a single spreadsheet containing the system constants and their values over multiple documents?
I'm preparing a new release where PartDesign::Bodies can be assembled without the need to wrap them into App::Part containers. Should be ready tomorrow. If you're using PartDesign for the design of solids this might speed up your workflow.I am designing a display case that will also have drawer type storage in its base portion.
Thanks again Zolko, you are awesome. Looking forward to the new and improved A4.
Sincerely,
Michael S. Olsen
Michael S. Olsen
Zolko wrote: ↑Thu Apr 16, 2020 9:19 pm with a Master Part: you create a new document called MasterPart, create there an Asm 4 Model, set your variables, and you include (per Asm4) this Master Part in all your documents where you need to use those variables. The Variables can be accessed by the ExpressionEngine "MasterPart#Variables.Length" ... should work with a spreadsheet also, but I never tried
Just tried on a test copy of my project and it worked perfectly!
Still getting a feel for the whole Link options, but now I have a much better idea of where the project needs to go.
Thanks again.
Sincerely,
Michael S. Olsen
Michael S. Olsen
- adrianinsaval
You don't need to link the file if you are using that syntax, it only needs to be opened, but that sounds more fragile (and potentially confusing) to me. If you make a link to the object you want to reference (it works with just a spreadsheet) you don't need to write the file name.
My understanding was that Asm4 was based upon the use of Link so now I am confusedadrianinsaval wrote: ↑Fri Apr 17, 2020 1:16 am You don't need to link the file if you are using that syntax, it only needs to be opened, but that sounds more fragile (and potentially confusing) to me. If you make a link to the object you want to reference (it works with just a spreadsheet) you don't need to write the file name.
Could you please give an example? Perhaps a couple of screen shots? Thanks.
Sincerely,
Michael S. Olsen
Michael S. Olsen
