Assembly 4 workbench
Zolko
Re: Assembly 4 workbench
Postby Zolko » Mon Jun 24, 2019 7:45 am
mfasano wrote:
Sun Jun 23, 2019 4:05 pm
I think I need some hand holding.
your file "rod.fcstd" is an Asm4 file, but the file "pendulum.fcstd" is not (I don't know wheter its Asm3 or Asm2+). So you probably created an Asm4 file, and then tried to assembly it with something else.
Please try to open the attached file "pendulum_Asm4" (in the same directory as "rod").
I tried to follow your instructions. I create the part with the new model macro. I create the assembly wih the new model macro; create the sketch with LCSs and import the part with the insert external part macro. When I try place the part, it highlights the part but I don't see the place linked part dialog box.
what workbench did you use ? In Asm4 there are no more macros, they should be toolbars now. You can try to download the Asm4 files (https://github.com/Zolko-123/FreeCAD_Assembly4) and move - or copy or link - the Mod_Asm4 folder to the folders where the workbenches are (oups, I use Linux, they are in ~/.FreeCAD/Mod/). You should have the Asm4 workbench installed.
pendulum_Asm4.FCStd
(9.99 KiB) Downloaded 51 times
mfasano
Postby mfasano » Tue Jun 25, 2019 1:18 am
I extracted assembly_v.04.zip and put the assemby4 folder in the mod folder of the assembly3 the branch of Freecad. I do not see a Mod_Asm4 folder in what I downloaded.
To try to place the inserted part I right click on the part in the tree and choose assembly in the popup menu and select place linked part in assembly. nothing happens. I was expecting the place linked part dialog.
Thanks again.
Zolko
Postby Zolko » Tue Jun 25, 2019 11:40 am
ah, OK, v0.4 is now old, Ams4 is at 0.5.3. Could-you please download the latest 0.5.3 zip, extract it, place the Mod_Asm4 directory into your workbench directory, and try again ?
https://github.com/Zolko-123/FreeCAD_Assembly4/
mfasano
Postby mfasano » Sat Jun 29, 2019 8:46 pm
Hello again;
I have downloaded the latest version of assembly 4 and I am able to link parts. I tried to place the rod so it is the LCS pivot2 is attached to LCS_0 of the parent assembly the part did not get placed as I expected. Also, when I saved the assembly exited Freecad and reopened the files, I can not see the part rod. I made sure to open both files.
Thanks.
rod.FCStd
(80.51 KiB) Downloaded 46 times
pend5.FCStd
(7.86 KiB) Downloaded 41 times
Zolko
Postby Zolko » Tue Jul 02, 2019 2:02 pm
Hello again;
hum, yes, there was somethin strange with the part "rod", it had a different icon also. I deleted and re-assembled it into the assembly, and now I think it works. Would you please check and tell if something is still wrong ? (you only need to place both files in the same directory and open "pend5.fcstd"
pend5.FCStd
(13.22 KiB) Downloaded 47 times
rod.FCStd
(89.22 KiB) Downloaded 49 times
dan-miel
Postby dan-miel » Sun Jul 14, 2019 2:07 am
I would like to try assembly 4 but I'm having trouble getting it going. I downloaded FreeCAD-asm3-Win64-Py3-Qt5-20190703, FreeCAD_Assembly4-master and FreeCAD-LinkStage3. Extracted all three. I put Mod_Asm4 into the mod directory, started FreeCAD .19 in the bin directory. There is not an assembly 4 workbench in the dropdown. I'm not sure what to do with the FreeCAD-LinkStage3 files.
Are there step by step directions on how to get this going?
Thanks.
Dan
Zolko
Postby Zolko » Sun Jul 14, 2019 8:30 pm
Hi, thanks for trying.
you seem to be doing everything correctly. I juste downloaded the Assembly4-master to be sure, and here it works as expected (I'm on Ubuntu Linux). Let's try to debug:
Do you see the Assembly 3 workbench in the drop-down menu ?
Do you have a way to start FreeCAD from the command line ? The output there could give valiable information about what goes wrong. Mine says:
hubertz @ipag-9102 ~ > FreeCAD-asm3_v0.10.2.AppImage
/tmp/.mount_FreeCAOWhNlu
FreeCAD 0.19, Libs: 0.19R16830 +1496 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Sheet Metal workbench loaded
Loading Assembly 4 WorkBench
If you have FreeCAD-asm3 then you don't need FreeCAD-LinkStage3 (I believe those are the source files)
dan-miel
Postby dan-miel » Mon Jul 15, 2019 3:07 am
I'm using Windows 10.
Assembly 3 is in the drop down and it starts.
I started FreeCAD from the command line but no messages showed up.
As long as it sounds like I have the correct files I'll try it on my other computer and let you know if it works there. I had to reformat this drive a while back so if Assembly 4 needs more support files they may be missing.
Dan
Zolko
Postby Zolko » Mon Jul 15, 2019 8:13 am
Ah, so I tested it on a Windows (7 Pro) and it works. But I have suddenly a question: where did you put (copy) the Mod_Asm4 directory ? Becasue there are 2 possible targets for the Mod directory :
1) the one that comes with FreeCAD-asm3, which is at D:/Applications/FreeCAD/FreeCAD-asm3_v0.10.2/Mod for me, and that contains the bin directory, one level up, from where I start FreeCAD.exe
2) the one with the standard Mod from the standard FreeCAD install, and which is at C:/Users/zhubert/AppData/Roaming/FreeCAD/Mod for me.
I put the Mod_Asm4 in #2 and it works, may-be you did put it in #1 ? If that directory #2 doesn't exist, please try to install a workbench through the Add-On manager - by using FreeCAD-asm3 - and see where that workbench lands: that's where you should copy Mod_Asm4.
dan-miel
Postby dan-miel » Mon Jul 15, 2019 10:26 pm
I have not had much luck. I was trying it on my laptop which I reformatted and now I have tried my desktop. FreeCAD 18 shows the Assembly 4 program but FC19 does not show it. It did show up once when I had put both files into both Mod directories but after I removed the file from the FC19 directory it has not shown up again. I have attached pictures from the module dropdown and a picture of the files in the main (#2) mod directory. I changed the name to asm4 trying to get it to read.
Dan Miel
Windows 10 Pro
Dell T3500
Main Mod Dir.JPG (37.82 KiB) Viewed 2136 times
