Assembly 4 workbench
Zolko
Re: Assembly 4 workbench
Postby Zolko » Tue Jul 16, 2019 7:20 am
dan-miel wrote:
Mon Jul 15, 2019 10:26 pm
FreeCAD 18 shows the Assembly 4 program but FC19 does not show it. It did show up once when I had put both files into both Mod directories but after I removed the file from the FC19 directory it has not shown up again.
thanks. So it's more a question of where tu put the workbench directories than an Asm4 problem first. May I ask you to try the following:
1) when you put the Mod_Asm4 directory in #1 (D:/Applications/FreeCAD/FreeCAD-asm3_v0.10.2/Mod) only, does the Asssembly 4 workbench show in FC19-asm3 ?
2) when you put the Mod_Asm4 directory in both locations (D:/Applications/FreeCAD/FreeCAD-asm3_v0.10.2/Mod and C:/Users/zhubert/AppData/Roaming/FreeCAD/Mod) do you see it in FC19-asm3 ?
3) When you see the Assembly4 workbench, did you try to open some of the example files ?
mfasano
Postby mfasano » Tue Jul 16, 2019 3:45 pm
I had the same problem as dan-miel with windows 10 and found if I moved mod-asm4 directory in the mod folder of the regular Freecad distribution it shows in Realthunders branch.
dan-miel
Postby dan-miel » Tue Jul 16, 2019 4:37 pm
The two paths I have for Mod folders are:
1: C:\FreeCAD-asm3-Win64-Py3-Qt5-20190703\Mod
2: C:\Users\dan-m\AppData\Roaming\FreeCAD\Mod
I have not been able to get Assembly 4 to show again, it doesn't make a difference if the asm4 folder is in #1 or #2 location. I did notice that a couple of other workbenches showed in FC 18 but not in 19, these were Assembly 2 and GDT. I'll attach those folders although I couldn't see what would make a difference. The assembly 2 folder was to large to attach so I attached the InitGui file, there was not a Init file.
I hope the picture will give you enough info about my directories.
Dan Miel
The one time I did get Assembly4 to show I did not open any files.
InitGui.zip
(1.13 KiB) Downloaded 26 times
GDT.zip
(157.86 KiB) Downloaded 33 times
dif mod folders.jpg (71.49 KiB) Viewed 2038 times
Zolko
Postby Zolko » Tue Jul 16, 2019 6:47 pm
So I think it's safe to conclude that the standard FreeCAD Mod directory (C:\Users\dan-m\AppData\Roaming\FreeCAD\Mod for you) is the good place to put Mod_Asm4. Since you seem to do everything correctly, my I suggest you remove Mod_Asm4 entirely from that .../Mod directory, and replace it with a freshly downloaded Asm4 ? (remember to extract first and then move/copy Mod_Asm4) May-be something got corrupted in all the manipulations.
Can-you post here the ZIP of the Mod_Asm4 directory that you have currently in C:\Users\dan-m\AppData\Roaming\FreeCAD\Mod ?
dan-miel
Postby dan-miel » Tue Jul 16, 2019 7:31 pm
Here is the folder. I 'll start redownloading.
Dan
Dans Mod_Asm4.zip
(77.28 KiB) Downloaded 39 times
Zolko
Postby Zolko » Tue Jul 16, 2019 7:42 pm
there is one file more: asm4wb_locator.pyc (which is the Python bytecode of asm4wb_locator.py). Don't know whether that makes the difference. May-be you can try to delete that file and start FreeCAD-asm3 again ?
dan-miel
Postby dan-miel » Tue Jul 16, 2019 8:03 pm
Done. I restarted machine, again. didn't make any difference.
Deleting the file did not make a difference in FC 19. In FC 18, Assembly4 disappeared from the dropdown until I put the file back, then it reappeared.
I you have any other straws I'll try them, otherwise I think I will remove all Python and FC versions and reload with just FC 19 and Assy4.
Thanks for your time. Dan
Zolko
Postby Zolko » Tue Jul 16, 2019 8:48 pm
I must admit that I've reached my level of incompetence, I'm sorry I can't help more. Yes, doing a fresh install is probably the only other possibility I see. May-be removing the C:\Users\dan-m\AppData\Roaming\FreeCAD\Mod directory entirely, starting FreeCAD-asm3, installing the SheetMetal workbench from the addons manager (which should re-create that directory) and putting a fresh Mod_Asm4 there ?
Alternatively, burning 13 black candles positioned on a pentacle wouldn't be less scientific.
dan-miel
Postby dan-miel » Wed Jul 17, 2019 5:31 am
Zolko. I'm sometimes I'm slow and other times I'm slower. I opened the Report panel and these error message were there. Do they help at all?
During initialization the error "inconsistent use of tabs and spaces in indentation (<string>, line 48)" occurred in C:\Users\Dan\AppData\Roaming\FreeCAD\Mod\GDT\InitGui.py
Please look into the log file for further information
During initialization the error "'charmap' codec can't decode byte 0x90 in position 1510: character maps to <undefined>" occurred in C:\Users\Dan\AppData\Roaming\FreeCAD\Mod\Mod_Asm4\InitGui.py
I'm not sure where the log file is otherwise I would have sent it.
Dan
Zolko
Postby Zolko » Wed Jul 17, 2019 7:21 am
that's a Windows/Python/Unicode error. The file does specify
# -*- coding: utf-8 -*-
but stupid Python/Windows still can't handle it. Apparently it's a Python console font thing. And I don't know where the log file is.
Can you please try to replace the InitGui.py file in Mod_Asm4 with the one attached ? I use some nice frames for comments in my code, in the attached one I removed them:
    ║            Initialize the workbench           ║
InitGui.py
(4.34 KiB) Downloaded 35 times
