Zolko wrote: ↑Thu Jul 18, 2019 6:15 am
Not as fancy, but if it works ... Can you please download that version and see if it solves those errors ?
I downloaded and it worked. I opened the control panel and unchecked the box in the Region and it still worked.
I opened all three of the sample files and all of them opened and showed in the screen.
Good work.
I have tried to load your WB several times in the last six months with the same results. I'm surprised that this problem hasn't been reported before.
Before I leave, when I open the assemblies I get a report similar to the one below. Can I really ignore the enumeration and the PropShape?
Thanks again.
Dan
Enumeration index -1 is out of range, ignore it
<PropShape> PropertyTopoShape.cpp(324): Recomputation required for document 'Bielle' on geo element version change: 1.13.70200.3.0 -> 1.14.70200.3.0
<PropShape> PropertyTopoShape.cpp(324): Recomputation required for document 'Cuve' on geo element version change: 1.13.70200.3.0 -> 1.14.70200.3.0
<PropShape> PropertyTopoShape.cpp(324): Recomputation required for document 'Bague' on geo element version change: 1.13.70200.3.0 -> 1.14.70200.3.0
<PropShape> PropertyTopoShape.cpp(324): Recomputation required for document 'Screw_CHC' on geo element version change: 1.13.70200.3.0 -> 1.14.70200.3.0
