Assembly 4 workbench
Grawp
Re: Assembly 4 workbench
Postby Grawp » Thu Sep 17, 2020 9:10 pm
I'm trying to use ASM4 for a simple task of modelling an enclosure for Raspberry Pi.
I have
  • a simple model of raspberry
  • a skeleton of the top part of the box
  • a skeleton of the bottom part of the box
and all these parts I have placed using the ASM4 into a Model.
I want to continue modelling the top and bottom part like:
  • Make little columns with mounting holes in the bottom part.
  • Change the top part to have a cutout for the ethernet port.
My problem is that I can't use SubShape Binder to e.g. bring those holes on the RPi to the bottom part because it would create cyclic dependency.
I really want the placement of the RPi in the skeleton box drive the placement of other more complicated features in the final box.
Can somebody recommend me some workflow how to do that? I'm out of ideas :(
The models are attached.
Edit: I've been thinking about it and conceptually there should not be a dependency cycle.
RPi is positioned using first features / datum planes in the bottom part of the box and then geometry from the placed RPi would be brought back to the bottom part and mounting holes and spacers would be made depending on previous feature in the bottom part and geometry from placed RPi which is depended on the same first features / datum planes. No conceptual cycle there, just a dependency diamond.
box.FCStd
(35.14 KiB) Downloaded 6 times
rpi.FCStd
(25.1 KiB) Downloaded 5 times
Zolko
Postby Zolko » Sat Sep 19, 2020 9:01 am
Many users have come with the same question, but this is a yet unsolved problem. You are right that there is no conceptual cyclic dependency in the features, but FreeCAD considers documents in its analysis of dependency, not the inner features, therefore it doesn't allow it.
What you can try is to create datum points on the relevant features of the RPi inside the RPi document, import (link) the RPi (Part) into an Asm4 Model, import the RPi datum points into the Model (there is a button for that), and create the solids (Bodies ?) for the housing inside the Asm4 Model using these points. So the RPi would be assembled into the housing, and the housing designed around it.
It would be nice to hear back from you whether this works.
Grawp
Postby Grawp » Sat Sep 19, 2020 11:57 am
Yess, thank you for confirming this.
As for the suggested workaround when I try it I'll let you know.
openfablab
Postby openfablab » Mon Sep 21, 2020 6:35 am
Experimenting with multi-level subassemblies I found that in Assembly4 we are urged to manually close every part file even if we did not modified it. It is not too convenient even with 10 parts (it is easier to restart application)... but with 100 parts it would be impossible. Is it normal behavior or I miss something? Or may be there is some button "close everything"?
Zolko
Postby Zolko » Mon Sep 21, 2020 9:56 am
nice, could you please show the Model tree ?
There is a misunderstanding here: if you recompute a part, then it's considered modified by FreeCAD, even you didn't modify the design.
it's the "normal" App::Link behaviour currently.
What I do is to quit FreeCAD, which gives you an "Apply to all" check-box. You're right that this should be improved, but it's a general FreeCAD stuff, not specific to Assembly4, therefore I invite you to post a feature-request in the Open Discussion forum.
openfablab
Postby openfablab » Mon Sep 21, 2020 10:29 am
May be tomorrow: now I have no access to that computer.
I see. Please check my message at that topic, is my analysis of situation with different assembly workflows correct?
https://forum.freecadweb.org/viewtopic. ... 64#p432364
openfablab
Postby openfablab » Tue Sep 22, 2020 6:30 pm
It is here:
bambuko
Postby bambuko » Thu Sep 24, 2020 4:32 pm
It is very basic question, so maybe it should be elsewhere?
If so I apologise...
When I fire FreeCAD and select Assembly 4 workbench, I get following reports:
17:27:03  Unknown command 'Part_Import'
17:27:03  Unknown command 'Asm4_insertRod'
17:27:03  Unknown command 'Asm4_FSparameters'
I wonder if someone has a clue what I am doing wrong, please?
OS: Windows 10 (10.0)
Version: 0.19.22474 (Git)
Hash: a44f8ffd427fa9b23b1f00dbf62d66cd152cd774
Python version: 3.8.5
Qt version: 5.12.6
OCC version: 7.4.0
Postby Kunda1 » Thu Sep 24, 2020 5:12 pm
Post your About info
louisgag
Postby louisgag » Thu Sep 24, 2020 5:21 pm
never saw it lead to problems, but I also have a similar message:
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 2b676020d2afe38216166fd074ef131e11df1ce3
Python version: 3.8.2
Qt version: 5.12.8
Locale: C/Default (C)
