Assembly 4 workbench
bambuko
Re: Assembly 4 workbench
Postby bambuko » Thu Sep 24, 2020 6:25 pm
Kunda1 wrote:
Thu Sep 24, 2020 5:12 pm
Post your About info
sorry, my bad :oops:
Have updated my original post
Zolko
Postby Zolko » Thu Sep 24, 2020 9:33 pm
bambuko wrote:
Thu Sep 24, 2020 4:32 pm
When I fire FreeCAD and select Assembly 4 workbench, I get following reports:
17:27:03  Unknown command 'Part_Import'
17:27:03  Unknown command 'Asm4_insertRod'
17:27:03  Unknown command 'Asm4_FSparameters'
it was a bug, should be fixed now, please update the workbench to 0.9.9
louisgag
Postby louisgag » Fri Sep 25, 2020 4:23 am
Fixed for me. Thank you.
bambuko
Postby bambuko » Fri Sep 25, 2020 7:00 am
...it was a bug, should be fixed now, please update the workbench to 0.9.9
Thank you, updated and OK
Postby Kunda1 » Fri Sep 25, 2020 1:26 pm
Thanks for fix, Zolko!
catman
Postby catman » Tue Sep 29, 2020 12:22 pm
The following is a quote from FreeCAD wiki on Expressions:
There is no concept of global variables in FreeCAD at the moment. Instead, arbitrary variables can be defined as cells in a spreadsheet using the Spreadsheet workbench...
I think this is not true any more.
Assembly4's variable feature in my view is exactly that.
Its not really global, however, because Its available only to Assembly4 parts. But I found that this feature even works when I move the variables folder out of the Assembly4 model and delete the remains of the Assembly4 model. The image below is an example of a very simple and intuitive-to-use parametric FreeCAD part
FreeCAD parametric part with Assembly4's Variable feature
Looking into the Python code files, it seems to me that the variable code is in the single file 'VariablesLib.py'. If that is not really closely connected to other Assembly4 code, I am thinking whether it would be an idea to move the variable part into a separate workbench?
That way all other FreeCAD documents could greatly benefit from this feature.
However, as its code from @zolko, I would like to ask whether he thought about such a thing before or if there is something that would prevent that on a conceptual level.
project4
Postby project4 » Tue Sep 29, 2020 12:28 pm
I've asked zolko a while ago how do I access variables from sub-sub-links and his answer was that it's impossible to set such variables, only read them...
His proposal was to create a separate document, which will be linked to all other documents that want to use it.
It's very much the same as having a spreadsheet that will be linked to other documents.
Apparently there is no real "global" variable solution after all.
Zolko
Postby Zolko » Tue Sep 29, 2020 1:06 pm
1) it's open/free source, you can copy it without my permission
2) you can create variables in pure parts: in the Assembly4 WB, create a new document, a new part, select the new part, and choose "Add Variable" and it will create the Variables placeholder to have variables in the part, which you can then use with whatever FreeCAD tool you want. Doesn't work with Bodies because they cannot contain such variables. Hum ... thinking about this ... would that make sense to create the Variables in the same document but outside a Body if no Part is selected ? EDIT: bah, I did it all the same: you can now create the Variables in any document.
3) there is already the "Dynamic Data" WB which also does that already (I think)
Therefore I'd not advise you to create a specific WB for variables.
catman
Postby catman » Tue Sep 29, 2020 1:14 pm
I did not think about referencing the variables from other files, just from the own document, mainly because a spreadsheet is a lot more cumbersome to use. For linking cross-document variables the spreadsheet allows to adds documentation more easily, maybe its better suited for this kind of use, indeed.
Very interesting. I would have expected that they could be addressed in expressions like any other object in the document:
documentName.Variables.<<myVariable>>
Thanks for that info.
catman
Postby catman » Tue Sep 29, 2020 1:33 pm
Works fine. I am not sure why the part selection is relevant. I think it does make sense to have one Variable leaf at the trees root level to contain all user modifiable parmeters for a document - especially if there are multiple bodies in it.
good point. Have not really checked that one out.
Thanks for the fast feedback.
