Yes, you are right. The rason is I tried to follow this tutorial: https://www.youtube.com/watch?v=n04M6nFvdxs I thought that is normal.
However it is now clear I need to understand more about the concept, can you suggest where can I find the most extensive description (I know about the base documentation). My aim is to keep parametric as far as I can.
Thank You! I will take care about it!Using an Asm4 Model is mandatory for assemblies, not parts.
Thank You, that is very useful hint for me!You can do that in a non-parametric way: in the Part WB, you convert your linked part to solid (Menu > Part > Convert to solid), then you copy this solid to the document where your cylinder is, and use boolean operation on the cylinder.
But I don't know whether it's possible to do it and keep the parametric design.
Kind Regards,
Tivadar
