I've got a question. Maybe it sounds stupid, but here it goes
Can I attach a subassembly/part by more than one attachment point?
Scenario: I'm creating a suspension system. I've got a rear shock that consists of 2 parts. the main body and the moving rod. Now I've created an assembly file that combines both of them, let's call it shock assembly. It has a sketch that is used for the movement of the parts (and the sketch also limits max positions). So far it works great, no problem. But...
Now I want to add this shock assembly to be part of a bigger assembly. The bigger assembly contains the two body parts that are dampened by the shock. So this bigger assembly consists of part A and part B. each has a point where the shock should be attached.
Attaching the shock to part A is quite easy of course. (lower shock LCS to part A LCS). But how do I now attach upper shock LCS to part B LCS? In an ideal world keeping the constraints of shock assembly (min/max).
Or is this not possible?
Do I need to embedd main body and rod separatly in the "master assembly"? And define the shock sliding and min/max limits in the master assembly? And do this again for each and every "master assembly" that is using this shock?
Thank you very much for your answer,
Kind regards,
Martin Schmidt
stats:
OS: Windows 10 (10.0)
Version: 0.19.23323 (Git)
Hash: 512d5c6141aec52b6eecc67370336a28fde862a6
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: English/Germany (en_DE)
