Assembly 4 workbench
mnesarco
Re: Assembly 4 workbench
Postby mnesarco » Sat Feb 20, 2021 1:33 am
Hi Friends,
Is there a way to access SubAssembly LCSs for alignment? Sub-Assembly parts are not available for selection.
I have a SubAssebly with some holes, and with proper LCSs on each one. But if I import it into another Assembly, the LCSs are visible but not selectable to align other parts. Only the origin of the subassembly is exposed. I am trying to put fasteners on subassembly holes.
Any suggestion on how to archieve that will be appreacited.
Thanks.
jmcornil
Postby jmcornil » Sat Feb 20, 2021 8:40 am
Hello
May be have a look to the "import" function
totalcad
Postby totalcad » Sat Feb 20, 2021 8:46 am
Hi!
As I know, there's an "import LCS" action from thee part's structure to the assembly's root. You can use that "root LCS" in sub-assembly..
Screenshot from 2021-02-20 11-20-59.png (49.66 KiB) Viewed 1050 times
Screenshot from 2021-02-20 11-21-32.png (68.3 KiB) Viewed 1050 times
mnesarco
Postby mnesarco » Sat Feb 20, 2021 4:24 pm
Thanks for teh info, but it does not work on my side:
mnesarco
Postby mnesarco » Sat Feb 20, 2021 4:28 pm
Ok, I figured out that to make it work, I need to import the datum object on each nested level.
EDIT: Oh, and I need to import one by one on each nested level :o :(
Zolko
Postby Zolko » Sat Feb 20, 2021 7:05 pm
Yes, this is sub-optimal. I have opened an issue for that problem, please feel free to add your remarks:
https://github.com/Zolko-123/FreeCAD_As ... issues/168
Markymark
Postby Markymark » Thu Feb 25, 2021 8:14 am
A quick question to make sure I have the correct understanding. Currently it is not possible to keep the final assembly and its sub-assemblies in one single file, correct? The only way is to keep its sub-assemblies in separate files, right?
Rgrds, Mark
Zolko
Postby Zolko » Thu Feb 25, 2021 11:08 am
currently, you can make an assembly in 1 file but only for 1 level, meaning no sub-assemblies. If you want nested assemblies (sub-assemblies and sub-sub-assemblies) then you need separate files.
niethitwo
Assembly4 - Parts not visible anymore
Postby niethitwo » Tue Mar 02, 2021 9:32 am
Hello folks,
first of all thanks for this awesome software!
I am trying the Assembly4 workbench on a arch linux 0.19 / 24212 git releasefor a project.
There I have two conceptual questions and one problem I ran into:
Problem:
I started a project on my notebook and it synced onto my other PC.
Before, every inserted part was a yellow building block and was visible in the 3D view.
After reopening the synced file on another computer, now it shows as a rounded blue rectangle with green arrow.
The same now happens when reopening the file on the original computer
I attached an image, the upper symbol indicated parts which are no longer shown.
The lower part is one which I newly created for comparison reasons, which is displayed.
All the properties are identical, even if I show all properties in the properties list window.
I guess the green arrow indicates, that it successfully linked?
What am I conceptually missing, that these linked parts are not displayed anymore?
How can I fix it? Recomputing didn't help, but also doesn't show any error message and seems to succeed.
Would be great not to have to remodel this whole assembly, or at least understand where my usage went wrong to avoid this issue in the future.
Conceptual questions
  • For now, I use every size of a single part with its own file.
    As others, I briefly tried to make general parts, which then with the new configuration parameters.
    However, I tried to not use enum but just a float/length type. It seems this parameter then is also changed for all linked parts and cannot be used for derived individual part sizes. So I have to create an enum with that size first, which I then can select individually for every link.
    This means the calculation has to be done in the part configuration spreadsheet, which defines the values of the enum?
    Assembly4 doesn't have a solver, so only one LCS-to-LCS relation is stored with an offset. This is not a "snap-to-this-then-to-that" as in Solidworks/Inventor and if I want to try such a thing the a2plus workbench would be the right one to give a ride?
Best
Postby Kunda1 » Tue Mar 02, 2021 12:01 pm
Hello folks,
Hello, I've merged your thread in to the main assembly4 wb thread. Please post your full About info when posting to the forum + make sure you're using the most up to date assembly4 version.
Welcome to the forum :wink:
