More constraint types needed
Re: More constraint types needed
Please edit your post and use code tags </> for log output. It improves readability.
Aaah, i think we are getting closer to what is happening !
Did you use the button with the green recycling symbol for recalculation ? This would reimport updated parts. If a part has been modified, you can run into the "topological naming" issue of FC. A small change in a part, and it's index of faces, edges,vertexes get completely mixed up. The result is the message "broken constraints".I translated one of the parts and called a recalculation.
Solving of the assembly (repositioning of moved parts) is done by the button with the rubic-cube. This does no reimport of the parts and the constraints do not break.
Am i completely wrong ?
KBWBE
Yes, you are completely wrong (sorry, )
(Incidentally, kbwbe, are you the/a developer of A2+ ?)
The command used for recalculation was:
(The python panel does not show it happen)
- Solved-after-good-prepositioning.png (530.7 KiB) Viewed 1215 times
Yes, it is my workbench.
From your screenshot i see, that your A2plus WB is not up to date. You are using V0.4.13, the recent version is V0.4.19.
Please update you A2plus WB, as V0.4.14 fixed a bug with broken constraints for FreeCAD 0.18.1. From your parts i see you are using it.
I think, this will fix the problem.
KBWBE
That fixed the problem indeed!
Super.
Now give me some time to contemplate assembling of cylindrical stuff further ...
Thanks so far for your efforts.
Roland
Super.
Roland
I made the assembly challenge more clear, and also more complicated.
See attached file.
The task for the assembler is to align the mounting holes of the flanges into defined planes. In this case at least two mounting holes of the different flanges aligned to coincide in the XZ-plane.
I think this challenge should be brought to more assembling attempts than only A2+.
Curious to hear suggestions!
See attached file.
- DoubleFlanged_ISO.png (33.48 KiB) Viewed 1167 times
- DoubleFlanged_TopView.png (11.18 KiB) Viewed 1167 times
- DoubleFlanged.FCStd
- (19.32 KiB) Downloaded 29 times
Here is a cheat to solve some related issues:
https://forum.freecadweb.org/viewtopic. ... 05#p305589
The message remains: more constraint types needed
(I only dare to suggest this because you are doing a great job with developing FreeCAD)
best regards
Roland
best regards
Roland
What do you think of this cheat to solve my challenge with A2+?
It is actually not good enough yet, because it needs nearly precise pre-positioning. Otherwise it pretends that constraints are inconsistent (which they are not)
Greetz
Roland
Greetz
Roland
- DoubleFlanged_cheat.FCStd
- (29.1 KiB) Downloaded 32 times
Hi Roland,
your "cheat" method is valid and you can do this this way (with helper solids), but you could get the same result with less work.
For example: If you always do your flange designs within XY-Plane and extrude along Z, you could assure that one hole is centered on X-Axis (or Y). Then import two flanges and the reduction cone. Simply rotate the flanges by the transform tool to your desired angle if necessary. Then apply a circularEdge constraint from each flange to the cone. This is very exact because a singular circularEdge constraint only moves the center point and the axis has been already correct before.
The resulting file you can use without problems as sub assembly in a main assembly.
P.S.: Or, if parts list is not so important, why not doing such simple reduction piece completely within PartDesign or Part WB and import it as complete unit to A2plus for further use.
KBWBE
Hi KBWBE,
For me an assembly WB should have the capability as discussed here. Without needs of placing things manually on the right spot.
Your proposal seems a capitulation. Although, admittedly, I would not know how to code my proposals in a python language. My capabilities are limited to the mathematical / topological understanding.
Remember in one of my first mails of this thread I proposed to have a virtual plane defined for a cylinder. Adding the helper solids was just one way of doing so. In the cheat for Toralf (https://forum.freecadweb.org/viewtopic. ... 05#p305589) I basically proposed a bounding box around a cylinder. And I made one, for one instance only, which does not automatically adapt to its "mother" shape. But it should, for an assembly WB to become really helpful.
In my experience, the Sketcher WB has all the needs for the 2D space. An assembly WB in 3D should be an upgrade of those principles.
Conclusion: we need to be able to extract such information from the components that are to be aligned, and the alignment constraints should be able to address those values.
Well, let us hope that some people can join this exchange of ideas.
I appreciate the discussion with you. And up to here many thanks for A2+ !
best regards,
Roland
best regards,
Roland
