import assembly into another assembly
Version: 0.18.13971 (Git)
Hash: 8e4dd8ca8496595d4718dc24c872f7ed668b2521
Python version: 2.7.14
OCC version: 7.2.0
Hi guys,
when I import an assembly (shaftAngleAssembly) into another assembly some of the items in the angleMount array do not show up.
Hope that is enough info as the final assembly is too large to upload.
Cheers.
Hope this helps.
I have found that the problem exists even when I create a new assembly (using the assembly 2 WB) and the only import is the shaftAngleAssembly.
OCC version: 7.2.0
Hi guys,
Cheers.
Hope this helps.
- shaft.FCStd
- (31.13 KiB) Downloaded 32 times
- angleMount.FCStd
- (20.77 KiB) Downloaded 31 times
- shaftAngleAssembly.FCStd
- (46.69 KiB) Downloaded 35 times
Re: import assembly into another assembly
Moved to Assembly forum.
you should give a try with A2p workbench.
- subassembly.FCStd
- (47.33 KiB) Downloaded 30 times
- mainassembly.FCStd
- (45.02 KiB) Downloaded 30 times
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Thanks for the info. Yes the A2plus Wb shows the detail. Unfortunately it has resulted in another problem, The blades assembly is now not visible.
- blades.PNG (26.82 KiB) Viewed 1562 times
Is it possible to post one of the "bladeRingAssembly"s for testing ?
Which A2p Version are you using ?
KBWBE
- roerich_64
Hi Klaus,
what is that: BR
Walter
what is that: BR
Walter
Die Liebe wird siegen, denn sie ist unzerstörbar
Hi Walter, it is the TabBar addon made by triplus. See addon manager.
KBWBE
- roerich_64
Attached below. I have attached the 2 files that are used to create that as well.
[/quote]
Version 0.14.19
Thanks for your assistance,
Gary.
[/quote]
Version 0.14.19
Gary.
- bladesRing.FCStd
- (139.91 KiB) Downloaded 32 times
- blades.FCStd
- (92.87 KiB) Downloaded 27 times
- bladeRingAssembly.FCStd
- (112.61 KiB) Downloaded 28 times
