Problem with a2+ import.
Hello FC people.
If I create an a2+ assembly, then import the joined bearing, the balls vanish. I don't understand why.
In addition, I've already reported this little glitch : the colors are not preserved as in the original part (although "update colors = true".) I really would like the red colored surfaces displayed as such into the assembly. I use cutaway massively because the transparency setting is no more sufficient (my projects have up to 6 levels of assembly nesting.) So some assembly would be undecipherable without this technique.
Any idea ? Thank.
Any idea ? Thank.
Re: Problem with a2+ import.
Hi @fcaduser,fcaduser wrote: ↑Thu May 09, 2019 1:10 pm Hello FC people.
Any idea ? Thank.
which version of A2plus do you have ?
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Hi kbwe.
V0.4.19
V0.4.19
Arggg, the joined file doens't appear ?
EDIT : i renamed the file, upload OK.
- 7204_ACCBM.fcstd
- (32.79 KiB) Downloaded 43 times
Thanks for the file. I can reproduce the problem and will look how to solve it.
KBWBE
Thank you very much.
The original model can be downloaded here (step ap 214), if needed :
https://www.skf.com/uk/products/bearing ... 04%20ACCBM
I think i have found the problem. Please checkout A2plus version V0.4.20.
This should fix it.
KBWBE
Good point, it works for this bearing.
Generally speaking, are colors of an imported part supposed always updated, too ? (with the right option ticked, of course.)
Yes.
P.S.: From one assembly level to the next higher one.
KBWBE
