I have some problem with assembly orientation of multi part projects.
FC info:
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: Polish/Poland (pl_PL)
Could someone explain me how to use A2plus workbench (or workbench I should use) to manipulate objects. My example have 4 objects from step files. Each time I try to manipulate object, I recieve error "The highlighted parts were not moved. They are not constrainded to a fixed part"
How I constrain fixed part? Its like I need to make FIX constrain to one part and rest is related to this fixed part?
Assembly example using step files
- error.jpg (11.19 KiB) Viewed 4583 times
- Assembly_Example.FCStd
- file
- (187.05 KiB) Downloaded 122 times
Re: Assembly example using step files
Moved to Assembly forum.
You need at least one part with the property "fixed Position" = True. You can change this in the property editor of the part.rebisar wrote: ↑Fri May 31, 2019 7:26 pm Could someone explain me how to use A2plus workbench (or workbench I should use) to manipulate objects. My example have 4 objects from step files. Each time I try to manipulate object, I recieve error "The highlighted parts were not moved. They are not constrainded to a fixed part"
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
But i dont see this feature in my properties menu.
When I look at youtube tutorials they have "fixedPosition =false/true", I need to activate something in settings?
- fix.jpg (102.98 KiB) Viewed 4542 times
The way you are using A2plus is not correct. The parts have to be imported from external files to the assembly. If doing so, each A2p object has the property "fixed Position" in the property editor of the combo view.
You can read this here: https://www.freecadweb.org/wiki/A2plus_Workbench
An additional tutorial is here: https://youtu.be/QMxcQ5tssWk
So put each of your STEP models to a separate file and import it from there. This is the most correct way. Alternatively you can use the A2p import function for direct import of STEP models to the assembly.
KBWBE
