a2plus/a2+ bug? freecad crashes when duplicating external object
In a2plus, when add an external object and then duplicate, FreeCAD would crash and disappear.
Instructions:
open sample-main.FCStd
[comment]This file contains a reference to an external solid located in sample-ext.FCStd
switch to A2plus v0.4.24 WB
select the solid
press shift key
select menu:A2plus>Create duplicate of part
left click once to create a duplicate
release shift key
press esc
[issue] FreeCAD crashes and disappears
FreeCAD details:
OS: Ubuntu 18.04.3 LTS (LXDE/Lubuntu)
Version: 0.19.17445 (Git) AppImage
Hash: 741dddf25485f692596faa9b7911e2e0f5d362a3
Python version: 3.7.3
Qt version: 5.9.7
Instructions:
select the solid
press shift key
release shift key
press esc
FreeCAD details:
Qt version: 5.9.7
- sample-main.FCStd
- (3.5 KiB) Downloaded 65 times
- sample-ext.FCStd
- (3.32 KiB) Downloaded 53 times
Re: a2plus/a2+ bug? freecad crashes when duplicating external object
The last A2 version is 4.26a does it work with that one?
Hi,bzb.dev001 wrote: ↑Wed Aug 07, 2019 2:41 am In a2plus, when add an external object and then duplicate, FreeCAD would crash and disappear.
this chrash seems to depend on the FC version.
I can reproduce it with:
OS: Linux Mint 18.3 (X-Cinnamon/cinnamon)
Version: 0.19.17499 (Git) AppImage
Hash: 6b1be38f35686faf21e1015bf562520929890870
Qt version: 5.9.7
I will try to investigate what's happening there...
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
The issue still occurs with the latest 0.19 build with A2plus 0.4.26a.
FreeCAD detail
Version: 0.19.17512 (Git) AppImage
Hash: 7b315d3a15f6c0a3e796b2bf000cb791092de079
Qt version: 5.9.7
FreeCAD detail
Qt version: 5.9.7
I have just moved from Windows to MX Linux and am having trouble with older assembly files that I try to open with A2Plus workbench installed. I have attached a sample file which was created before I had my new installation of FreeCAD on Linux. With A2Plus installed FreeCAD crashes when I try to open this file. This only happens with assemblies - single parts open. Strangely I can also create a new assembly with A2Plus installed.
When I removed A2Plus and installed Assembly 2 it opened the file. I have since added Assembly 4 to my installed workbenches and it opened the file. I also have exploded assembly installed which is working fine.
I can get by with what I have installed (I think) but thought this information might be helpful.
OS: Debian GNU/Linux 10 (buster)
Version: 0.18.4.
Qt version: 5.11.3
Version: 0.18.4.
Qt version: 5.11.3
- Chord Connector Bolt, Washers & Nut _ M16 X 125mm.FCStd
- (41.5 KiB) Downloaded 39 times
opening your file with FC0.18.4 (AppImage) causes a crash on my system too, whereas opening it with recent FC0.19-daily works fine.
Perhaps you should upgrade to FC0.19.
KBWBE
Thanks kbwbe. I would like to but I would need some help as to how to go about that on Linux - Version 19 is not in any of my repos for MXPerhaps you should upgrade to FC0.19.
Just for starters though, you can download and make the 0.19 AppImage executable and then give it a try which includes all it's dependencies hence it's name. https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre currently FreeCAD_0.19-21514-Linux-Conda_glibc2.12-x86_64.AppImage
I still run both Windows and Linux Mint 19.3 in dual boot, I started in Linux by using the AppImage, progressing onto the Daily build and now I compile as it's reasonably easy but you stay on the AppImage if you feel comfortable using it.
Please be aware that Assembly4 relies on the App::Link framework introduced with FreeCAD v0.19, therefore you'll not be able to make much use of it with v0.18Laurie Hartley wrote: ↑Thu Jun 11, 2020 6:30 am I have since added Assembly 4 to my installed workbenches and it opened the file.
Version: 0.18.4.
Syres and Zorko thank you for your responses. I have downloaded the V.19 appimage. Just one question do I have to uninstall my existing 18.4 version of FreeCAD?
