Hi Ceremcem,ceremcem wrote: ↑Tue Sep 03, 2019 6:27 amThe document is very outdated, but still helpful on this topic: https://www.dropbox.com/s/k40drc9rlkflr ... n.pdf?dl=0freecad-heini-1 wrote: ↑Mon Sep 02, 2019 2:05 pmHow can two cube surfaces be counter-aligned or aligned?ceremcem wrote: A short question
You can select both surfaces and add a "PlaneAlignment Constraint".
thank you so much for your help. I know this document and I know the "PlaneAlignment Constraint".
the question is: how can you change the direction? Is there a switch or a button?
I found out that you can rotate the part with the move tools, that changes the direction, aligned or opposite, I'm looking for an easier way.
A2 plus has such a tool, like to see in the following two pictures: Best regards
Wilfried
