kbwbe wrote:ping
I may be on to something. Fixing the tolerances in the parts, turning the shells into solids and fusing the result gives something that passes Check Geometry without a peep. Not sure if this is a general solution yet, but it looks promising.Roland wrote:ping
I've attached a couple of well behaved assemblies. The result passes and can be fused to another part without complaints.
If you run into more problematic assemblies, please pass them to me. I can always use more test data.
wf
