Reimplementing constraint solver
- DeepSOIC
Re: Reimplementing constraint solver
well, I have fixed it all locally already, and i'm now getting the segfault you described. Investigating...
- DeepSOIC
what bothers me most, when doing it in python console, it works =(
Ups! That one was unexpected indeed!
In case it serves for something:
New File, select Sketcher WB, insert new Sketch, select point tool, click => crash.
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f0fcc4c8f20]
#1 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(PyObject_Call+0x33) [0x7f0fce77e993]
#2 0x7f0fd10c6a7e in Py::Callable::apply(Py::Tuple const&) const from /home/abdullah/github/freecad-build/lib/libFreeCADGui.so+0x4a
#3 0x7f0ef4c556f6 in FCS::ParaObject::makeParameters(Base::UnsafePyHandle<FCS::ParameterStore>) from /home/abdullah/github/freecad-build/Mod/ConstraintSolver/ConstraintSolver.so+0x348
#4 0x7f0ef4d462f6 in FCS::G2D::ParaLine::makeParameters(Base::UnsafePyHandle<FCS::ParameterStore>) from /home/abdullah/github/freecad-build/Mod/ConstraintSolver/ConstraintSolver.so+0x78
#5 0x7f0ef742abb0 in Sketcher::FCSSketch::addLineSegment(Part::GeomLineSegment const&, bool) from /home/abdullah/github/freecad-build/Mod/Sketcher/Sketcher.so+0x14a
#6 0x7f0ef742a6e6 in Sketcher::FCSSketch::addGeometry(Part::Geometry const*, bool) from /home/abdullah/github/freecad-build/Mod/Sketcher/Sketcher.so+0x144
#7 0x7f0ef742a4ad in Sketcher::FCSSketch::addGeometry(std::vector<Part::Geometry*, std::allocator<Part::Geometry*> > const&, std::vector<bool, std::allocator<bool> > const&) from /home/abdullah/github/freecad-build/Mod/Sketcher/Sketcher.so+0x141
#8 0x7f0ef742a219 in Sketcher::FCSSketch::setUpSketch(std::vector<Part::Geometry*, std::allocator<Part::Geometry*> > const&, std::vector<Sketcher::Constraint*, std::allocator<Sketcher::Constraint*> > const&, int) from /home/abdullah/github/freecad-build/Mod/Sketcher/Sketcher.so+0xd7
#9 0x7f0ef7258e96 in Sketcher::SketchObject::solve(bool) from /home/abdullah/github/freecad-build/Mod/Sketcher/Sketcher.so+0xb4
// Call
Object apply( const Tuple &args ) const
=> PyObject *result = PyObject_CallObject( ptr(), args.ptr() );
if( result == NULL )
throw Exception();
return asObject( result );
HParaObject child = HParaObject(
Py::Callable(reinterpret_cast<PyObject*>(v.type)).apply(Py::Tuple()));
*v.value = child;
Ask more if you need
Well yours does not crash from the UI either...
- DeepSOIC
It seems to help adding this:
before calling the type.
This should probably be placed in a variety of places in constraintsolver, I have to figure out where exactly...
Now I get a new crash, in the destructor of TaskDialog, when I close the sketch:
Base::PyGILStateLocker lock;
TaskDialog::~TaskDialog()
for (std::vector<QWidget*>::iterator it=Content.begin();it!=Content.end();++it) {
delete *it; // <-- crashes here
*it = 0;
- DeepSOIC
I have pushed a fix for makeParameters. I'll open a discussion on this topic...
- DeepSOIC
BTW, is it possible to quickly get the old sketcher in our development branch? I want to use sketches to quickly mock up some geometry for testing with console, and the fact that sketcher is broken really gets in the way of that...
Quickly with compiling, sure: in SketchObject::SketchObject(), change:
solvedSketch = std::make_shared<FCSSketch>();
solvedSketch = std::make_shared<Sketch>();
This may be related to the fact that I have removed the advance solver dialog, as it was getting in the middle of the new implementation.DeepSOIC wrote: ↑Thu Apr 09, 2020 2:52 pm It seems to help adding this:before calling the type.Code: Select all
Now I get a new crash, in the destructor of TaskDialog, when I close the sketch:Code: Select all
TaskDialog::~TaskDialog() { for (std::vector<QWidget*>::iterator it=Content.begin();it!=Content.end();++it) { delete *it; // <-- crashes here *it = 0; } }
The sketcher on this branch lacks at this moment the find DoF (hyperlink on the solver messages). I want to have other things working before setting for a common interface.
