Reimplementing constraint solver
Mark Szlazak
Re: Reimplementing constraint solver
Postby Mark Szlazak » Wed Mar 25, 2020 3:17 pm
My apologies if this is not the right place for these questions.
Does your program provide "under-constrained", "fully-constrained" and "over-constrained" feedback?
If so what technique/algorithm is used to determine those conditions?
Thanks.
abdullah
Postby abdullah » Wed Mar 25, 2020 3:36 pm
DeepSOIC wrote:...
I have pushed some cosmetic self() to getHandle() renaming for coherence, but you may have to rebase before pushing or there is chance the repo does not compile (if you used self() in the meantime).
DeepSOIC
Postby DeepSOIC » Wed Mar 25, 2020 4:12 pm
No, not yet. That's what that scary diagnose does. It's not yet implemented in ConstraintSolver.
DeepSOIC
Postby DeepSOIC » Wed Mar 25, 2020 4:32 pm
I have pushed some cosmetic ...
abdullah
Postby abdullah » Wed Mar 25, 2020 4:35 pm
Thanks.
There are some requirements:
1. You need a rank-revealing decomposition.
2. You must reveal which rows/columns (parameters/constraints) of the original matrix give rise to redundant/conflicting constraints or are not constraint parameters. Sketcher does this with a QR decomposition, using the R matrix. Eigen keeps track of the transpositions/permutations of the pivoting during decomposition, which allows to map the R matrix to the original rows/columns
QR is rather expensive computationally. I think it was gael from Eigen suggested using other cheaper rank revealing decomposition (LU I think it was), but then is the problem of identifying redundant/conflicting and unconstrained parameters.
For reasons I do not understand, to get the unconstrained parameters, you need to use a dense QR with full pivoting. SparseQR is not good enough for this (or the needed tracking is not exposed in eigen or I do not understand how to use what it gives).
If I implement the diagnosis, I will use QR because it is what I know and "kind of" understand.
abdullah
Postby abdullah » Wed Mar 25, 2020 4:38 pm
I know you expect other "help" and other "speed". I am not there yet. :|
Mark Szlazak
Postby Mark Szlazak » Wed Mar 25, 2020 4:57 pm
I know DeepSonic has been re-implementing things with (dual?) quaternions and i got interested in them with regards to screw-displacement theory. I do not know if that is the direction this could evolve with regards to 3d-constrains in sketches and assemblies. In any case, i found a paper on this topic of screw-theory and reciprocal screws but not in terms of quaternions. I suspect it could be modified for quaternions. It does claim very fast real-time constraint evaluation (under, over, full).
https://www.hindawi.com/journals/mpe/2016/1761968/
DeepSOIC
Postby DeepSOIC » Wed Mar 25, 2020 5:13 pm
ConstraintSolver has nothing to do with screw theory right now. I was using something from it to implement placement interpolation (SCLERP) in FreeCAD.
ConstraintSolver has no 3d part yet, and thus does not use quaternions in any form. When 3d comes, dual quaternion is going to be used, but in a manner very different to how it's used in SCLERP. That will actually be a challenging conflict to implement a sclerp for constraintsolver, should the need arise.
DeepSOIC
Postby DeepSOIC » Wed Mar 25, 2020 5:23 pm
I am planning to attack ellipse next.
DeepSOIC
Postby DeepSOIC » Wed Mar 25, 2020 7:19 pm
I've added a bunch of issues toConstraintSolver issue tracker, as a reminder and as thought-provoker.
