Reimplementing constraint solver
DeepSOIC
Re: Reimplementing constraint solver
Postby DeepSOIC » Sat Mar 28, 2020 10:58 pm
No, things are worse than that. I changed a to 0.1, and now it takes 32 subdivisions to arrive at error better than 1e-6 :(
And in this case, the accuracy is improving extremely slowly as the number of subdivisions is increased, which is depressing. Something's wrong with my estimate.
abdullah
Postby abdullah » Tue Mar 31, 2020 3:01 pm
I guess you are looking for a general method for other closed curves too, not only for an ellipse.
Surely you know about the specific infinite series for the ellipse.
Something like "Infinite Series 2" of:
https://www.mathsisfun.com/geometry/ell ... meter.html
Then you do not have to subdivide...
DeepSOIC
Postby DeepSOIC » Tue Mar 31, 2020 4:05 pm
No, I didn't. Is there a version for an arc, not full ellipse?
DeepSOIC
Postby DeepSOIC » Tue Mar 31, 2020 4:08 pm
Well, a general method is better than ellipse-specific, but either will do.
abdullah
Postby abdullah » Tue Mar 31, 2020 5:30 pm
None for an arc to my knowledge.
I found as advice, what you were doing:
http://mathforum.org/library/drmath/view/51945.html
I have started rewriting the solver interface of SketchObject to accomodate different solvers.
DeepSOIC
Postby DeepSOIC » Tue Mar 31, 2020 5:51 pm
Great news! :D
abdullah
Postby abdullah » Mon Apr 06, 2020 4:30 pm
Great news!
I have a question regarding ParameterStore and HParameterStore.
I have been looking at your example code to create the "Sketcher.h" equivalent of FCS, which I called "FCSSketcher.h"
I appears to me that in FCSSketcher.h, I need an HParameterStore to... well ... to store the parameters of geometry and constraints.
I initially wrote something like:
class SketcherExport FCSSketch : public SketchSolver
    TYPESYSTEM_HEADER();
public:
    FCSSketch();
private:
    FCS::HParameterStore parameterStore;
This obviously won't work because HParameterStore is designed to only be susceptible of being created via the static make() function, so the constructor won't be able to initialise the object and I won't be able to arrive to the body of the constructor to call make.
This makes me think that maybe you thought it to be used in a different way... and that is the question. How did you intend to use it from c++.
DeepSOIC
Postby DeepSOIC » Mon Apr 06, 2020 4:59 pm
I guess you are getting a compile error that parameterStore must be initialized. Add : parameterStore(Py::None()) to the constructor, and then fill it in in constructor code by calling make method.
Or we can change it to support construction via new, I wanted to do that.
abdullah
Postby abdullah » Tue Apr 07, 2020 6:01 pm
DeepSOIC wrote: ...
More questions.
So far, in FCSSketch, I have these data members:
private:
    // Solver
    // Interface classes
    std::vector<GeoDef>         Geoms;
    std::vector<FCS::G2D::HParaPoint>     Points;
I am here:
int FCSSketch::addPoint(const Part::GeomPoint &point, bool fixed)
    //std::vector<double *> &params = fixed ? FixParameters : Parameters;
    // create our own copy
    GeomPoint *p = static_cast<GeomPoint*>(point.clone());
    // create the definition struct for that geom
    GeoDef def;
    def.geo  = p;
    def.type = GeoType::Point;
    FCS::G2D::HParaPoint hp = new FCS::G2D::ParaPoint();
    hp->
Here I have to do the setValue(). In the Python code you pass parameter store to the ParaPointPy. I have learnt that this is then use with a Dic and setAttrib. I think that the c++ way you thought may differ from that. Do I have to do a setAttrib? Could you give me an example of what to do in this addPoint function?
DeepSOIC
Postby DeepSOIC » Tue Apr 07, 2020 6:10 pm
The easiest is to call makeParameters method of ParaPoint.
Also, you can assign attributes x and y of parapoint directly, they are public. You can use setAttr, but it is for python, and thus has no compile-time type checking.
If you modify ParameterRefs x and y of parapoint after calling update, you should call update() again. There is a "touch" mechanism for automating the update calls to an extent, but it only really works one time. I have not bothered to set up a comprehensive mechanism, it seems to be too much of a challenge for too little gain.
