Reimplementing constraint solver
DeepSOIC
Re: Reimplementing constraint solver
Postby DeepSOIC » Tue Apr 07, 2020 6:26 pm
Sorry, I've been seriously distracted from programming, hope to return in a few days.
abdullah
Postby abdullah » Wed Apr 08, 2020 1:29 pm
No problem, I am still slower than you, you can take your time ;)
About:
std::vector<ParameterRef> ParaObject::makeParameters(HParameterStore into)
Did you intend to pass HParameterStore by value?
This involves calling the copy constructor for UnsafePyHandle, which calls the copy constructor of Py::Object, and you get away with having a new reference for the same object because of its implementation... However, wouldn't we prefer to past it as a reference to const and avoid all that process? Maybe I am missing something...
abdullah
Postby abdullah » Wed Apr 08, 2020 2:21 pm
How about changing:
virtual std::vector<ParameterRef> makeParameters(HParameterStore into);
to
virtual std::vector<ParameterRef> makeParameters(HParameterStore into. bool fixed=false);
Because fix() means a fixed parameter, like GCS, right?
BTW, I came up with something like this:
int FCSSketch::addPoint(const Part::GeomPoint &point, bool fixed)
    // create our own copy
    GeomPoint *p = static_cast<GeomPoint*>(point.clone());
    // create the definition struct for that geom
    GeoDef def;
    def.geo  = std::make_unique<GeomPoint>(p);
    def.type = GeoType::Point;
    FCS::G2D::HParaPoint hp = new FCS::G2D::ParaPoint();
    hp->makeParameters(parameterStore);
    hp->x.savedValue() = p->getPoint().x;
    hp->y.savedValue() = p->getPoint().y;
    if(fixed) {
        hp->x.fix();
        hp->y.fix();
    def.startPointId = Points.size();
    def.endPointId = Points.size();
    def.midPointId = Points.size();
    Points.push_back(hp);
    // store complete set
    Geoms.push_back(def);
    // return the position of the newly added geometry
    return Geoms.size()-1;
DeepSOIC
Postby DeepSOIC » Wed Apr 08, 2020 5:35 pm
How about changing:
to
I have no objections!
As for copying... yes it does make a copy, but I see no reason to avoid it (after all, it will be copied numerous times later anyway, as ParameterRef objects are made).
abdullah
Postby abdullah » Thu Apr 09, 2020 1:19 pm
I have pushed some rudimentary sketcher interface. The reason is that using makeparams() crashes FreeCAD in this line:
https://github.com/DeepSOIC/FreeCAD-ell ... t.cpp#L142
I have no clue why, but I am guessing that makeParams is to be used differently.
Basically the only thing to be checked at this time is creating of solver geometry from sketcher geometry and back. Only points and lines. Both segfault.
Could you take a look?
DeepSOIC
Postby DeepSOIC » Thu Apr 09, 2020 1:30 pm
Can you give a step-by-step of what to do?Open sketcher, draw a line -> segfault?
DeepSOIC
Postby DeepSOIC » Thu Apr 09, 2020 1:38 pm
I get a rather cryptic compile error:
[59/113 0.9/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\Sketch.cpp.obj
[60/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchGeometryExtensionPyImp.cpp.obj
[61/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\AppSketcher.cpp.obj
FAILED: src/Mod/Sketcher/App/CMakeFiles/Sketcher.dir/AppSketcher.cpp.obj
C:\PROGRA~2\MICROS~2\2019\BUILDT~1\VC\Tools\MSVC\1420~1.275\bin\HostX64\x64\cl.exe  /nologo /TP -DFCAppSketcher -DHAVE_ACOSH -DHAVE_ASINH -DHAVE_ATANH -DHAVE_SNPRINTF -DQT_CORE_LIB -DQT_XML_LIB -DSketcher_EXPORTS -DUNICODE -D_CRT_NONSTDC_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_OCC64 -D_UNICODE -Isrc -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src -I. -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App -Isrc\Mod\Sketcher\App -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\.. -Isrc\Mod\Sketcher\App\.. -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\inc -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\bin\Include -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\eigen3 -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtCore -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\.\mkspecs\win32-msvc -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtXml /DWIN32 /D_WINDOWS /W3 /GR /EHsc /MDd /Zi /Ob0 /Od /RTC1 -DFC_DEBUG /Zm150 /bigobj /showIncludes /Fosrc\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\AppSketcher.cpp.obj /Fdsrc\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\ /FS -c S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\AppSketcher.cpp
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\xutility(1784): error C2280: 'Sketcher::FCSSketch::GeoDef &Sketcher::FCSSketch::GeoDef::operator =(const Sketcher::FCSSketch::GeoDef &)': attempting to reference a deleted function
S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\FCSSketch.h(135): note: compiler has generated 'Sketcher::FCSSketch::GeoDef::operator =' here
S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\FCSSketch.h(135): note: 'Sketcher::FCSSketch::GeoDef &Sketcher::FCSSketch::GeoDef::operator =(const Sketcher::FCSSketch::GeoDef &)': function was implicitly deleted because a data member invokes a deleted or inaccessible function 'std::unique_ptr<Part::Geometry,std::default_delete<_Ty>> &std::unique_ptr<_Ty,std::default_delete<_Ty>>::operator =(const std::unique_ptr<_Ty,std::default_delete<_Ty>> &)'
        with
            _Ty=Part::Geometry
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\memory(1969): note: 'std::unique_ptr<Part::Geometry,std::default_delete<_Ty>> &std::unique_ptr<_Ty,std::default_delete<_Ty>>::operator =(const std::unique_ptr<_Ty,std::default_delete<_Ty>> &)': function was explicitly deleted
        with
            _Ty=Part::Geometry
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\vector(1021): note: see reference to function template instantiation '_OutIt *std::_Copy_unchecked<_Iter,Sketcher::FCSSketch::GeoDef*>(_InIt,_InIt,_OutIt)' being compiled
        with
            _OutIt=Sketcher::FCSSketch::GeoDef *,
            _Iter=Sketcher::FCSSketch::GeoDef *,
            _InIt=Sketcher::FCSSketch::GeoDef *
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\vector(1036): note: see reference to function template instantiation 'void std::vector<Sketcher::FCSSketch::GeoDef,std::allocator<_Ty>>::_Assign_range<_Ty*>(_Iter,_Iter,std::forward_iterator_tag)' being compiled
        with
            _Ty=Sketcher::FCSSketch::GeoDef,
        with
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\vector(1046): note: see reference to function template instantiation 'void std::vector<Sketcher::FCSSketch::GeoDef,std::allocator<_Ty>>::assign<Sketcher::FCSSketch::GeoDef*,void>(_Iter,_Iter)' being compiled
        with
        with
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\vector(1044): note: while compiling class template member function 'void std::vector<Sketcher::FCSSketch::GeoDef,std::allocator<_Ty>>::_Copy_assign(const std::vector<_Ty,std::allocator<_Ty>> &,std::false_type)'
        with
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.20.27508\include\vector(1062): note: see reference to function template instantiation 'void std::vector<Sketcher::FCSSketch::GeoDef,std::allocator<_Ty>>::_Copy_assign(const std::vector<_Ty,std::allocator<_Ty>> &,std::false_type)' being compiled
        with
S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\FCSSketch.h(160): note: see reference to class template instantiation 'std::vector<Sketcher::FCSSketch::GeoDef,std::allocator<_Ty>>' being compiled
        with
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(54): note: see reference to class template instantiation 'boost::arg<9>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(53): note: see reference to class template instantiation 'boost::arg<8>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(52): note: see reference to class template instantiation 'boost::arg<7>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(51): note: see reference to class template instantiation 'boost::arg<6>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(50): note: see reference to class template instantiation 'boost::arg<5>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(49): note: see reference to class template instantiation 'boost::arg<4>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(48): note: see reference to class template instantiation 'boost::arg<3>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(47): note: see reference to class template instantiation 'boost::arg<2>' being compiled
S:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\boost/bind/placeholders.hpp(46): note: see reference to class template instantiation 'boost::arg<1>' being compiled
[62/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchAnalysis.cpp.obj
[63/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchObjectPyImp.cpp.obj
[64/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchObject.cpp.obj
FAILED: src/Mod/Sketcher/App/CMakeFiles/Sketcher.dir/SketchObject.cpp.obj
C:\PROGRA~2\MICROS~2\2019\BUILDT~1\VC\Tools\MSVC\1420~1.275\bin\HostX64\x64\cl.exe  /nologo /TP -DFCAppSketcher -DHAVE_ACOSH -DHAVE_ASINH -DHAVE_ATANH -DHAVE_SNPRINTF -DQT_CORE_LIB -DQT_XML_LIB -DSketcher_EXPORTS -DUNICODE -D_CRT_NONSTDC_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_OCC64 -D_UNICODE -Isrc -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src -I. -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App -Isrc\Mod\Sketcher\App -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\.. -Isrc\Mod\Sketcher\App\.. -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\inc -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\bin\Include -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\eigen3 -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtCore -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\.\mkspecs\win32-msvc -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtXml /DWIN32 /D_WINDOWS /W3 /GR /EHsc /MDd /Zi /Ob0 /Od /RTC1 -DFC_DEBUG /Zm150 /bigobj /showIncludes /Fosrc\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchObject.cpp.obj /Fdsrc\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\ /FS -c S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\SketchObject.cpp
        with
            _Ty=Part::Geometry
        with
            _Ty=Part::Geometry
        with
        with
        with
        with
        with
        with
        with
        with
[65/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\SketchPyImp.cpp.obj
[66/113 0.8/sec] Building CXX object src\Mod\Sketcher\App\CMakeFiles\Sketcher.dir\ExternalGeometryExtensionPyImp.cpp.obj
ninja: build stopped: subcommand failed.
16:34:51: The process "S:\Qt\cmake3110\bin\cmake.exe" exited with code 1.
Error while building/deploying project FreeCAD (kit: FC64)
When executing step "CMake Build"
16:34:51: Elapsed time: 01:30.
Can you please take a look, I don't understand...
DeepSOIC
Postby DeepSOIC » Thu Apr 09, 2020 2:00 pm
Also.
S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Mod\Sketcher\App\FCSSketch.cpp:77: error: C2872: 'Constraint': ambiguous symbol
 could be 'FCS::Constraint'
 or       'Sketcher::Constraint'
abdullah
Postby abdullah » Thu Apr 09, 2020 2:08 pm
I pushed a fix. Please check again ;)
abdullah
Postby abdullah » Thu Apr 09, 2020 2:11 pm
Also.
I pushed a second fix.
I am surprised I was not getting even a warning...
