OS: Linux Mint 19.1
Version: 0.18.4.
Python version: 3.6.8
Qt version: 5.9.5
I have a situation using A2Plus V0.4.29 where I would like to place a part in an assembly a known distance from a feature of that assembly. Ideally, I'd like to place the part, maybe use the Planes Coincident constraint to align them, and them add a dimensional constraint to locate the part along the plane the correct distance from said feature. However, I don't see a tool to accomplish this.
Is this something coming in the future? Are there any suggestions for an alternative approach for what I want to do given the current capabilities?
Thanks
Bill Lugg
Dimensional constraints in A2Plus - SOLVED
Re: Dimensional constraints in A2Plus
Hi Bill,
In some of the constraints is a parameter called offset. It is by default 0. If you change it, you have what you want to achieve.
Sure enough, the coincident plane constraint with the appropriate offset does exactly what I want it to do.
Thanks for the help.
Bill Lugg
Bill Lugg
