Big merge day
ickby
Re: Big merge day
Postby ickby » Wed Sep 18, 2013 5:54 pm
hehe, let's say I have much confidence in the FreeCAD community finding cases I missed during testing. Which, in regard to the complexity, wasn't thorough enough, I have to admit :)
gestalt73
Re: Big merge day
Postby gestalt73 » Wed Sep 18, 2013 7:07 pm
Ah, now I understand. Ok.
I have a 50 part "assembly" done in 0.13, but it's my first experience in FreeCAD and so I did everything in the Part Workbench (didn't understand the virtues of PartDesign).
I'm recreating a few of the simpler parts in dev-assembly PartDesign after following the new tutorial, and I get (and like) the relative assembly->product->part coordinate system.
So far the sketch solver seems to work well, I'll get a couple of parts in and see how the Assembly solver works.
Thanks for the tips, it makes so much more sense to me now.
Alan
kwahooo
Re: Big merge day
Postby kwahooo » Thu Sep 19, 2013 5:52 pm
If I'm correct assembly constraints work only for imported STEP/BREP atm. The constraints are doing nothing for PartDesign parts and bodies (or my workflow is wrong:)
ickby
Re: Big merge day
Postby ickby » Thu Sep 19, 2013 8:21 pm
It works also for part design. In assembly workbench, you have a tool which adds a New part into the active assembly. This new part holds a body. You can use This body for normal part design work and Assemble it later.
triplus
Re: Big merge day
Postby triplus » Thu Sep 19, 2013 9:16 pm
Looking good. I am tempted but will wait until it lands on daily PPA to try my first assembly (in the easy way).
Is parametric relation preserved? Can you edit added part from PartDesign after it was added to Assembly and will the changes be updated in Assembly without adding it again?
ickby
Re: Big merge day
Postby ickby » Fri Sep 20, 2013 5:07 am
yes of course.
kwahooo
Re: Big merge day
Postby kwahooo » Fri Sep 20, 2013 6:17 am
ickby wrote:It works also for part design. In assembly workbench, you have a tool which adds a New part into the active assembly. This new part holds a body. You can use This body for normal part design work and Assemble it later.
I know about that but the problem is different. Assembly tools (align, coincident) cannot translate those bodies or translation is incorrect. I will provide steps to reproduce the issue later today.
ickby
Re: Big merge day
Postby ickby » Fri Sep 20, 2013 6:36 am
Good idea, I'm sure there are a few bugs which needed to be hunt down! Just a few remarks on the current implementation:
1. Most likly you know that already, but for completeness: you can't assemble bodys directly, they need to be inside a part. Only bodys in parts can be used with constraints.
2. If you model something inside a body, you should place the initial sketch on the xy plane. If you choose any other, the transformations get messed up between partdesign and assembly. If you want to transform your design apart from the assembly module, then transform the body. This is a known issue.
triplus
Re: Big merge day
Postby triplus » Fri Sep 20, 2013 11:31 am
ickby wrote:yes of course.
Great!
kwahooo
Re: Big merge day
Postby kwahooo » Sat Sep 21, 2013 11:18 am
ickby wrote:2. If you model something inside a body, you should place the initial sketch on the xy plane.
It seems i have to:
1. Start on the xy
2. Add other features on different planes
3. And then use assembly constraints.
4. Cannot edit (or add) features added in (2), because a sketch view is wrong
Another thing - when I switch first time from Assembly (1 component with 2 parts) to Part Design, FreeCAD show me a message:
No body was found in this document, and none could be created. Please report this bug.We recommend you do not use this document with the PartDesign workbench until the bug has been fixed.
