Good morning.
Thanks for your answer:
The message a i got from addon managerr was:
On branch master
Your branch is behind 'origin/master' by 45 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: Examples/Asm4_Example1/Bague.fcstd
modified: Examples/Asm4_Example1/Bielle.fcstd
modified: Examples/Asm4_Example1/Cuve.fcstd
modified: Examples/Asm4_Example1/Screw_CHC.fcstd
modified: Resources/library/Fasteners.FCStd
Untracked files:
(use "git add <file>..." to include in what will be committed)
Examples/Asm4_Example1/Bague.fcstd1
Examples/Asm4_Example1/Bague.fcstd2
Examples/Asm4_Example1/Bielle.fcstd1
Examples/Asm4_Example1/Cuve.fcstd1
Examples/Asm4_Example1/Screw_CHC.fcstd1
Examples/Asm4_Example1/aaa.FCStd
Examples/Asm4_Example1/aaa.FCStd1
Examples/Asm4_Example1/aaa.FCStd2
Examples/Tutorial2/
Resources/library/Fasteners.FCStd1
__pycache__/
no changes added to commit (use "git add" and/or "git commit -a")
I deleted the folder ~/.FreCAD/Mod/Assembly4 then reinstalled Assembly4 using the addon manager.
The bug was solved.
Thanks again.
Saludos.
Frecad 0.19 Possible bug in assembly4
Re: Frecad 0.19 Possible bug in assembly4
I have uploaded many FreeCAD video tutorials to my YouTube channel
nice. I think that I'll add a note about failing of updating, because sometimes this seems to happen. Cheers
that is an annoying issue that can happen with the Addons manager when you also have cloned the repo locally.jruiz wrote: ↑Wed Jan 22, 2020 10:10 am Good morning.
On branch master
Untracked files:
Examples/Tutorial2/
__pycache__/
The bug was solved.
Thanks again.
Saludos.
I use to solve the issue deleting the WB through the Addons manager itself and then reinstall it using again tha Addons manager...
This should be avoided or at least addressed at the Addons wiki in FC.
- adrianinsaval
I asked if an option to force reinstallation of a workbench in these cases can be added, in case you guys are interested:
https://forum.freecadweb.org/viewtopic. ... 10#p362464
I got a round a similar error message when I changed the source and had uncommitted changes like this:
click uninstall the workbench, then click reinstall it, restart FreeCADeasy!
